Root Rom Help (CM9 Change)
RyRyV2
Member
Ok guys i been running unofficial CM9 since it came out. I really love it. But im tired of DLing a new nightly pretty much everyday. I was wondering what would be a good ROM to go to that is Stable and is pretty much the same as CM9. I dont know to much about all the different ROMs. And if you suggest a good ROM can you tell me a good kernel to get with it also.
Thanks Alot Guys
Any sense rom will most if not everything working out of the box, such as mikg. I love love love aosp roms, they usually require some tinkering but its way worth it in the long run. Or you could go with decks reloaded which is spectacular right now, everything working! Mason kernels right now are king for any i
Aosp rom gingerbread or ics, just make sure you pick the right one for the rom you will be using. My set up is cm 7.2 rc1 ( yes I know its up to rc3) Mason kernel. 15 rc3 SBC fso, papasmurfs tweaks and some other odds and ends. But I love it big time, my phone runs great!
Thanks alot
I ran cm7 before i wanted to try something new. i just DLed reloaded .44 but didnt really like it. i don't know if i did something wrong but i don't like Go Launcher.
What would CM9 be Like is it a Sense or ASOP or what
Agreed, Team Dirt CM9 is the best out there. Mazda is a great guy to boot. He personally helped me with some issues I was having and I got it resolved.
Is there a tablet mode in the cm 9 by team dirt? I just nanded back to it to see and I can't find it. I'd like to mess with it if I could find it.
Ok noob question what do i have to do to get it then and how do i get a2sd to work
SORRY VERY NOOB QUESTIONS
edit: oh yea what happens to everything on my sd do i lose it all?
