Root [ROM] ICS Android 4.0.1
I'm running this ROM currently. It's def stable and runs great. I'm using it as my everyday, everything works EXCEPT WiMAX and Camera, oh and no soft keys since I don't really use either 1 of those often I have no grips.
I'm realitively new to this and flashing it was a breeze.
Oh and let me add this. you might of seen the vids but there is nothing like having ICS in your hands. I'm godsmacked at how much better it is over GB.
I'll go ahead and make a video to show
thanx for sharing that. gonna download now. looks like it is time for some dessert.:D
No prb at all man. I will say this though. Download CPU tuner from the market and iver clock the cpu when running this rom. It makes it smoother.
Have any good comparisons of this vs deck's build? Deck is on his 8th pre-alpha, but it seems like they have different issues with each build (which is to be expected at this phase).
No, I'm sorry I don't. I thouht about using decks but went with this instead.
never tried that app. i use setcpu and never really needed to look for another app as this one i have been using since i first rooted my phone. can you set governors with that app?
I didn't have much time to play with it but this is the first Rom for me that started to automatically download my apps from the market to the phone.
About a dozen of them.
The Deck build was really sketchy with pre 6 which is the last one I had tried.
I've DL'ed Pre-alpha 8 so I'll try that probably tomorrow night.
The TN was very nice though. The first one I felt I could use as a daily. I would have run it for the day yesterday but I was showing someone Boot Manager.
Naters
I think that's actually the changelog for the previous release, if you look under the links for the new release it should have the newest changelog.
Can you use Sprint's Visual Voicemail with this?
I'm not sure. With the updated VVM app you could try it.
Psousa, thanks for the heads up on that. I didn't have time to find the right changelog so I deleted what was there.
The Team-Nocturnal forum linked in the OP isn't up to date as it seems to be at XDA.
Has anyone else noticed the second LED light on the other side of the speaker grill when running this rom? I noticed when running this rom and this rom only that a Green LED light appears in the right side of the speaker grill.
This only happens when my phone was locked and the color of the green was alot different from the usual dull green left side notification light. it was like a bright greenlight green. and instead of flashing it faded in and out
CM7 and decks use that led also for notifications.
