Curtis1973
Android Expert
lol the chinchilla is a BEAST!! Going to have to assemble a search party headed Les Stroud ala Survivor man to find JM lol. and thank you dark.
Actually, I believe even this uses mine as a base as well.
It doesn't look like it, but that's the whole trick to it. People underestimate what can be done to a stock rom these days.
been busy workin' on aosp gb and soon gp's cm9.
gp's cm9
gp's cm9
You could be retaining something that conflicts.So can anyone tell me why it boot loops for me unless I do a complete wipe? I really need a way to keep all my stuff without having to format /data.
When Android first boots (this is very simplified, but gets the point across), it copies everything to Dalvik cache, and then runs from there, this is why the first boot on a new rom takes so long (and why Android is so durable). When it copies over to Dalvik, if there are files there it will do a comparison between the new file, cache and dalvik cache and then will pick whichever matches the other files best. This is part of the virus protection. This is why whenever there is an issue, we always tell people to start fresh, and wipe everything. This forces the phone to use the files you want. The more modified a file, the more likely it is to revert.
Odds are, your system prefers an older file it is retaining somewhere, and that file is crashing things.
As far as I know Quickmemo works just fine.Thanks Leslie, I'm gonna start looking at Logs to find the problem. Besides that; Is there ANY fix for Quickmemo and possibly removing the boot sound?
Strange. I will take a look when I have a chance.yeah quick memo has issues from Aeneas build I think. I haven't edited it at all. I did leave it in this new build just in case. can remove if need be.
I'm aware that it has Aeneas as a base. I was just saying that I will not be releasing whatever theme I would make from it as another Aeneas based ROM. I would likely decompile, change a few things and it would just be for temporary personal use.
Been busy workin' on AOSP GB and soon GP's CM9.
