Root [ROM] Incredibly Re-EngineeredX v1.00 [01-17-11]
Status
Not open for further replies.
PatHoge
Note: I did not create this ROM. See the original thread at XDA HERE
Like the rom? Rate the thread and thank me! =)
This Rom is tested and supported on only 320/340 Droid X
Whats the big difference in this and Liberty? I saw how someone had edited a few things from GummyJar and called it a [MOD], but not a full ROM... just wondering, just flaming at all... work is work, and appreciated always.
Well, I think the creator did more than just edit a few things. He actually rebuilt the entire ROM using Liberty as a base.
Also, in my opinion it's faster than Liberty. That being said, I'd test it out for myself if I were you since no two Xs are the same.
Downloaded it. It feels like I'm just running a theming of Liberty. There is a quirk. The swype doesn't work on it. Only the android keyboard works.
It's a nice rom and all as I like Liberty, but I can't recommend it until swype works. You can peck out keys on swype but you can't do the swyping motion.
Perhaps it could have been better beta tested? I mean the lack of swyping is a big issue for the DX.
I'm going ahead with my app restoration anyway, but I don't think I'll be taking this rom seriously and won't be recommending it to newbies until the swype issue gets fixed. I will continue to test it out for now.
Steven
Edit: I just restored apps. This is fast, but I tried to go into keyboard settings and got a force close each time. It happened to someone else over at XDA, too.
I can't recommend this until this serious issue is addressed.
Im sure this rom will be great. Im downloading right now.
One thing that I loved about liberty was how easy it was to change from one theme to another. Im going to go back to yellow after I flash this rom.
Thanks for the find OP
Its fast. I like the theme...I cant overclock. Liberty toolbox wont open up..im going back to Liberty..once issues are fixed ill try again.
Hey bro,
Next time just ask before basing a rom off of someones work. Instead of having multiple roms based on something, you should just contribute whatever work you do to the liberty team or start a rom from freash :-P
Hey bro,
Definitely ...this is supposed to work like a community, not the corporate world.
Hey bro,
For the record, the rom was not developed by the op, he's just the messenger. You can express your concerns to the developer by choosing the link to his page at xda. It's in the op.
Steven
Steven
Yes, thank you.
However, I got a message from the creator of this ROM and he would like the threads to be deleted since he's receiving a lot of grief about this over at xda. (His original thread has now been deleted.) So Steven, if you could go ahead and do that that'd be great. Thanks.
Yes, thank you.
You should probably just close the thread so no one can post anymore.
It would probably be quickest to send Steven a private message if you want this thread deleted more promptly.
Status
