yeah i did in this update, its awesome
updated op to version 3.3
here are some changes
Version 3.3 2/25/2013
-Updated google now
-Updated play store to 3.10.14 not inverted, no "keep shopping" window now
-Updated more themeing
-Updated supersu to v1.10
-Updated to thunderbolt tweaks
-Updated ortriggers kernel to latest alpha v2.0
-Added google play music plus v1.1 dark theme
-Added nexus 4 bootanimation, removed n7 one
-Added LMT Launcher V1.91
-Removed xenoamp
-Removed some other files
-Removed goo.im stuff, they had slow dl speed
-Might have fixed exchange not sure if i did or not
-Changelog now in root of your sdcard
-Other things i forgot?
awesome! because i have always liked aokp better than cm has some cool extra features that cm does not have, if its smoother ill definitily start buildng for aokp instead of cm
I know there are multiple methods for root- but could you pls. point which one for root & unlocking bootloader, now that I got this stupid V8 update..dont want to push my luck too much as this is my primary device...thanks a bunch.
follow these instructions
http://androidforums.com/spectrum-a...20-bootloader-pwnage-tool-lg-spectrum-4g.html
Hi azoller1 and you gurus-
per my last post..the same logo (fireworks merging in X) keeps spinning and nothing happening. I did all steps incl. bootloader unlocking as suggested and then flashing this ROM with all steps upto "disable flash recovery" and then rebooted my LG Spectrum...its just hung for last 50 mins or so, despite 2 battery pulls ad reboots.
I shd. say that I DO NOT have a nandroid backup. I didnt have much data in my phone as I lost my DROID X and got this spectrum to replace it. So while I dont need to recover any personal data (I can sync it later with outlook)...becasue this is my primary phone I really need to get this working on this ROM ASAP.
Waiting for you gurus to shout out....Pls. Help!!
Which version did you flash? 3.2 or 3.3? if it was 3.2, do a full wipe and flash 3.3. Are you able to put a different zip on your sd card without accessing it through your phone?
find the rom called Slimdroid here on the forums do a clean flash of that rom, then flash this rom right over it without wiping anything
I'm sorry for being a noob but its constantly reminding me to do the OTA update. From what I read, I lose root access if I update. So what do I do? I'm on v3.3.
