Root [ROM][July14] Icy Fusion V5.0 | Smooth | Tweaked | Themed | Battery
WOW!! That is weird im on slim droid making my way to this rom and i downloaded cwm app and it shows a rom download icy fusion V4.2???? WTF?????? I must be missing something
Lol!!! Damn!!! I was hoping you were uploading new version!! After slim droid i did a full wipe and installed 3.3. Now stuck in never ending bootloop. Should i have not done a full wipe??
I'm currently running V2.9 and want to update. When I go to goomanager I don't see 3.4, do I have up update to 3.2 and then I'll see it?
Edit: I noticed you're not using Goomanager anymore. Looks like I'll download it on the computer and go from there.
Edit, Edit: can I go straight to 3.4? or Do I have to go to 3.3 then 3.4?
Just flashed to 3.4, I kind of like 2.9 better, I don't really see much different. Hopefully it'll be more stable though.
Also, when you're in camera you still can't go to the gallery or now called the "album"
I also can't see picture messages.
Thanks AZ!! Got it finally installed and running great! With a notification drop down this time!! Looking forward to your updates. Thanks for all your hard work!!
I just installed 3.4 (Full Wipe, Wipe all Caches), and now I've got issues:
DID NOT GO INTO NEW PHONE WIZARD ON FIRST STARTUP
NO STATUS BAR
UNABLE TO MAKE CALLS
MESSAGING FORCE CLOSES
WON'T CONNECT WITH WIFI
Tried to VOL Down + Power to reboot into CWM, but it just brings up the Factor Hard Reset screen.
What the hell did I do wrong?!?!
uploading version 4.0
here will be the changes
Version 4.0 (3/10/2013)
-Rebased ROM Off Of ZV8 Now
-Updated SuperSU to V1.25
-Updated Xposed Framework App to V2.3 to prevent Bootloop now
-Updated Google Music Plus
-Updated Busybox
-Updated To LGHome3 UI V3.0
-Updated Bravia Engine
-Added Stock ICS Gallery Back
-Added Some Battery Tweaks
-Added Galaxy S3 Sounds
-Added Stock LG Email App To Try And Get Exchange Working
-Removed Emoze App
-Removed AwesomeBeats V5 For Now
-Removed all Themeing for now until i Finish it Completely
-Removed Xperia Album App
-Removed All Placebo Effect Tweaks
-Removed Some Useless Files
-Lot Smoother
-Better Battery Life
-Lots of other Fixes And Changes Under The Hood
-Fixed Some Permissions In Updater Script for Less Boot problems
I had the same problem as hairytrucker so I switched back quickly. going to do the slimdroid then put new 4.0 on. I have to say AZ I always have excellent battery life with your ROMs, I love it, keep it up
Update: flashed slimdroid, worked fine, but when I used ROM Manager to flash icy fusion, it gets stuck on the boot animation... any ideas?
