finished..dont really have time to flash this, any testers out there? here you go!
link- Chameleon OS Nightly on AndroMirror
Looking good so far, booted fine, 4g, GPS, running smooth. I'll keep running it, hoping battery will be better than AOKP... Might want to start a sperate thread for it!
In the icy fusion ROM, can I still tap the side of the phone to move the cursor?
Pretty sure this is a function of the LG UI/Keyboard.
I doubt you'll find much outside of stock with that feature.
In the opening post of this thread, under installation instructions, you say download zip and extras...
... to what is "extras" referring
new build is up, check 2nd post for changes!
BTW, I just flashed this ROM finally and the "tap to move cursor" function is still available.
located in settings/gestures
OK I will re upload 4.7 thanks for telling me
