SimsDelt
Android Expert
Not my ROM just found this over at rootzwiki and wanted to share it. Seems to be amazing on battery.
(link removed)
[ROM] Kevlar DX
(link removed)
[ROM] Kevlar DX
BulletProof ROMs by G6Droid Presents:
KEVLAR-DX
Built on the latest OTA .596 GingerBread, with System Applications compiled from The Android Open Source Project (AOSP), this full-featured ROM for the Droid X, brings you speed & stability based on a proven OS for the Droid X.
Perrformance is driven with “Imoseyon Scripts” as used in other Popular ROMS such as APEX (pre-rc1), ZombieStomped, & Liberty. Though emphasis on speed was a goal, Stability & Battery Life are the ultimate factors stressed in this ROM.
Unlike other ROMS, where some things work well, & others not all, Everything in Kevlar has been tested to ensure functionality. Whether you need GPS for Navigation, or just to make a phone call or send a simle MMS, Kevlar performs everytime.
Installation Instructions: 1st you MUST already be on a .596 based ROM to use Kevlar. To ensure a bug free installation, please follow the installation instructions carefully, & don’t try to take short cuts.
• Download KevlarDX file to your SD Card. It is recommended that you download via PC & Transfer the File to your SD Card, so that the MD5SUM can be checked to ensure there is no file corruption. If you must download from the mobile platform, WiFi is recommended.
• Bootstrap &Reboot into Clockwork Recovery
• Create a Nandroid Backup of your current system
• Wipe Data/Factory Reset. This is Required.
• Wipe Cache
• Flash the KevlarDX ROM File
• Reboot. Be Patient, The 1st boot can take a few moments.
• Complete Setup & Be Sure to Sync your Google Acct.
• After Intial Reboot, Let the phone go thru its syncing process before you reboot or install additional apps. Do Not Restore ANY System Data from other ROM builds.
(link removed)
MD5sum : F5D82765FE7693F848EEAE0D1463BD12
Thanks to NateMz & Mobile_Sensei for the theme files, Huge thank you to Mobile_Sensei For Helping Me Do Graphics, Layout, & for hosting my ROM on his Server. Thanks to Kejar31 for his pointers on compiling apps from source.
Follow Me On Twitter : @G6Droid
::: SCREENSHOTS:::
KEVLAR-DX
• Wipe Cache
(link removed)
::: SCREENSHOTS:::
I'm on stock gb, now, though. Don't know if I'm going to try it, though. I may be through playing around until my next phone.
