Root ROM manager problem
rsjet
Member
So I was gonna use ROM manager for the first time to install CM6 and after selecting my ROM it says "will reboot into clockwork recovery and install rom".
But when it reboots it came to a screen showing a triangle with an exclamation point and a little green android robot next to it. Been like that for 5 minutes.
Is it doing something? I'm afraid to reboot lest I brick it. Some help is appreciated.
Edit: I figured out it went to that screen since ROM manager failed at installing the file. When I hit power, it brought me to clockworkmod recovery. I had to manually select the file using clockwork.
Do you have clockworkmod installed? That sounds like you don't, and it's just booting to the default recovery.
I do, and that's why I was worried, but as I found out, as soon as I hit power it brought me to clockworkmod. It was just waiting for me to press power I guess.
help help help! i downloaded cm6 and none of my old apps are on the market. says they can't be found. ?????
You should probably do a search. I believe there is a fix that you download from ROM manager. Not sure though. If you can't find it by searching, try your question in the CM6 thread.
Yes, it was strange. I'm guessing it failed at installing the file so for some reason showed the default recovery screen. I have no idea, i'm just guessing here.
But as soon as I hit power, it went to clockwork... so go figure lol.
Im new to rooting and ROMs, but my Nexus One is doing the same thing, but pressing the power button doesn't do anything. Any advice?
What's it doing exactly? Can you even load Rom Manager from the market? If so, try reflashing Clockwork (top option in Rom Manager). If that doesn't cut it, you might try the Nexus One root forum since we are Incredible users and aren't likely to know the quirks of the N1.
Iowa (by the way, where in Iowa? - I lived in towns around DM for 20 years).
Is there anything to be gained by using Rom Manager, other than perhaps it's a bit simplified (nicer UI) as compared to doing things in Recovery?
I came from the Eris which normally has the Amon Ra recovery when rooted, therefore RM wasn't an option. I'm quite comfortable doing what needs to be done in Recovery - and I see various threads where ROM Manager seems to be the cause of a problem. Because of that I've never even tried to use RM - am I missing anything of note?
In a word, no. ROM Manager is, like you said, a simplified version. I've never used RM personally. My feeling is, if it ain't broke, don't fix it. If you're comfortable booting into recovery I wouldn't bother with RM.
Side note-have you tried any ROM's yet, Hoto?
Thanks WD.
Nope, I'm waiting for 2.3 of Incredibly Re-engineered, figure that'll be the first one I flash (a couple of days after release to see what the early adopters say about it). Unlike the Eris, the DInc doesn't really NEED a new ROM to be usable - so I'm not in a huge hurry to get rid of the stock ROM.
I came from the Eris which normally has the Amon Ra recovery when rooted, therefore RM wasn't an option. I'm quite comfortable doing what needs to be done in Recovery - and I see various threads where ROM Manager seems to be the cause of a problem. Because of that I've never even tried to use RM - am I missing anything of not:cool:e?
Yeah I don't use RM for flashing Roms. I prefer flashing directly in Clockwork. Seems to be the most surefire method for me.
Thanks WD.
Completely agree. I always wait a couple days after a release to see what, if any, issues pop up. I'll say this, Re-Engineered 2.3 better be unbelievable the way it's getting hyped up. I almost wish the "testers" would stop coming into that thread adding their tidbits like "it's great", "you're all gone love it", etc because it's just adding to the hype machine. I know it will be a solid build and I'll more than likely flash it, but it's getting out of hand in that thread lately.
