Root [ROM] [MikRoms] Incredibly Re-Engineered v2.3.2 [02-25-11]
chingy51o
Seems to me like everyone that is having problems applying the mods is simply not reading the directions. Please just take a minute and read everything. Some of these are MetaMorph files and some of these are flashable. If you read the title of the Mod (For example if you look next to Battery Mods you will see it says MetaMorph files) if youll find what you need. Thanks! One more thing... A lot of people have been asking me for things that have already been done! Just carefully look through all of the mods before making a personal request!!!
Like the rom? Rate the thread and thank me! =)
Check it out! Install Incredibly Re-Engineered Android ROM On HTC Droid Incredible
So after many long nights have been spent working on this rom, here it finally is. This is the first rom I have put together and hope you will all be able to enjoy it as much as me. I can't thank aamikam enough for helping me out with this project. Your a great friend and there's no way in hell i would have been able to put this together without you. Not to even mention you were my whole motivation to take on this project. If you guys dont know who aamikam is you should definitely check out his work (mainly on the evo). It is FLAWLESS. Not many dev's put as much time in their work as he does. This guy takes no shortcuts. I would also like to extend my thanks to the all the other Android dev's out there who made making this rom possible. Without further adieu, i present to you the fastest rom ever... Incredibly Re-Engineered
Features
  • This rom is 100% Evo Framework
  • Deodexed rooted rom
  • Lou's #8
  • 4-in-1 Reboot menu
  • Zipalign on boot
  • Custom animations by aamikam
  • JsChiSurf power widgets
  • DSP Manager
  • Heavily optimized to give you the fastest HTC Sense Rom out there!
  • Myn's Rosie Settings (Thanks for letting me use this Myn!)
  • Modified FlashPlayer to work with Hulu
  • 5 Column App Drawer
  • Optical Trackpad Wake
  • Themed Gingerbread Keyboard By reprod
  • Much much more that i cant think of
  • Custom Rosie Based Off Deficitism Sexy Rosie (huge thanks for writing this code)
Included Apps
  • Spare Parts
  • Wireless Tether
  • Facebook
  • Hulu
  • Adobe Reader
    Note: All Removed Apps, Stock Wallpapers, and Stock Sounds have been can be found on the sd card "Incredibly_Re-Engineered_Optional"
Changelog
February 25th v2.3.2:
  • Fixed update script a little bit more
  • Updated Market to v2.3.3 and themed and optimized it
  • Updated Gmail to v2.3.4.1 and themed and optimized it
  • Tweaked Rosie a little bit to improve responsivness
  • Added all of the Colored Wallpapers to Incredibly_Re-Engineered_Optional/Wallpapers folder on the SD card
  • Added HtcTwitter.apk and com.htc.TwitterWidget.apk to the Incredibly_Re-Engineered_Optional/Removed_Apps folder on the SD card (I guess i forgot to add these earlier)
  • Added back in Adobe Reader
  • Cleaned up a few apks
  • Added a new themed XDA App
  • Fixed permissions so lockscreen gestures work now (Something got messed up on 2.3.1)
  • Updated host file so ads should be blocked (words with friends should work still!) let me know if this gives people issues with
  • Other minor things none of you guys will notice
  • Note: This is not a huge update nor is it required. If your happy with what you have and everything is working do not feel pressured to flash this.
  • Please perform a FULL WIPE before flashing!
February 15th v2.3.1:
  • Fixed update script so that it is now compatible with the newest clockwork revovery
  • Set SD Card read speed to 128 by default
February 8th v2.3:
  • Way way way faster than previous versions
  • All of the APK's were rebuilt and optimized once again
  • GMaps in data/apps now
  • JsChiSurf Vanila Lockscreen w/ Gesture's & 4 Tab Unlock (To restore HtcLockscreen, navigate to system/app and rename HtcLockscreen.bak to HtcLockscreen.apk andthen do a hot restart)
  • Remapped HtcClockWidget to open up DeskClock (Thanks aamikam and JsChiSurf)
  • Remapped Gallary and Music buttons in DeskClock to work with HTC Apps (Thanks JsChiSurf)
  • Redeodexed the whole Framework and ported tweaks
  • Updated Facebook and GMaps
  • Added XDA App
  • Highly themable (See 3rd post)
  • Tons of working mods that do not break optimizations (See 2nd post)
  • Updated FlashPlayer and modded to work with Hulu
  • Fixed and cleaned up some images
  • Re-Added HTC News along with the widget
  • Removed HTC_IME (Optional download in 2nd post)
  • Re-Added Flickr
  • New Gingerbread keyboard with working text prediction and dictionary
  • Tons of more little things that you guys probably wont even notice
  • And of course as always "I'm probably forgetting some things" lol
    Thanks to aamikam for everything
    Thanks to neurotk for testing on command and being a good friend
    Thanks to suprafreak1000 for testing the themes and taking tons of screnies
    Thanks to all the donaters
January 17th- v2.20:
  • Bluetooth fixed for real this time!!!!
  • Fixed EMMC so you can play music from internal storage
January 16th- v2.10:
  • Changed to Lou's #8 Kernel (Can't believe how smooth/fast this rom is with this kernel. Thanks a ton Lou)
  • Updated Flashplayer and Hulu app
  • Fully Themed Menus Icons!
  • Optimized GMaps and Voice Search
  • Themed GMaps (thanks aamikam, hopefully they dont update it soon!)
  • Re-did Notificantion Pull-Down (looks a lot better imo)
  • Changed and cleaned up some statusbar icons
  • Got rid of most of the metallic gray in the theme and switched it back to white
  • New default wallpaper
  • Changed Clock Widget to Mik's FlipClock
  • Updated Market to v2.2.11
  • Other minor fixes/changes
  • Bluetooth still broken...
January 9th- v2.00 (Huge Update):
  • Even Faster Now!
  • Changed to Stock HTC Kernel 2.6.32.17 (for those having issues with Lou's #6)
  • Re-designed Rosie by Me
  • Added Hulu App
  • Fully Themed Now (took aamikam's base theme,can be found in 3rd post, and made changes to it)
  • Enlarged text in Battery Meter
  • JsChiSurf new powerwidgets bar that includes his app
  • Tweaked animations a little more for ALL HTC packages (not just the frameworks)
  • Updated Wireless Tether
  • Deflated resources.arsc in all apks
  • Removed the album art from Htc Lockscreen music player and made the background transparent
  • Enlarged text size of the date on the HTC Lock Screen bar
  • Black Semi transparent Market app (Thanks virus for the original transparent version)
  • Black Gmail app (Thanks virus)
  • ALL highlights are green in all apps except GMaps.
  • New HTC Flip Clock skin
  • New Dialer Skin (Thanks Virus)
  • Bluetooth is still NOT working. Please do not post about this issue in the thread. It was either Bluetooth or boot loops. i chose to get rid of the boot loops
    Thanks to neur0tk for being my little guinea pig, Stoney for helping me out with some images and last but not least aamikam for his amazing work...
January 2nd- v1.10 (Maintenance Release):
  • Addressed all known bugs (Bluetooth, MMS, etc)
  • Removed Ads
  • Removed some stock HTC Wallpapers and added some custom ones
  • Changed Default Ringtones
  • Re-Added FriendStream to fix the sync issue
December 30th:
  • Initial Release- v1.00
Disclaimer
Please remember that I will not be held responsible for anything that happens to you phone. Except of course making it well, Incredible. =)
A Full Wipe is REQUIRED before flashing this rom. If you choose not to do this (for who knows what reason) please do not post any problems you are having!
Please report any issues so i can continue to improve this rom.
Ladies and gentlemen, please fasten your seat belts and hold on as this rom is about to take you on the ride of your life... Enjoy!
Note: If i forgot to mention ANYONE please please please send me a PM letting me know. I'm not trying steal credit from anyone. Thanks guys!
Please note that because all apks and images have be optimized for maximum efficiency, themeing carelessly will break these optimizations
Mods
From here on you can access all my mods here (Thanks to scuccia for hooking me up with the server!)
Mods For 2.3
Unthrottled Data (Note: This will not force close anything and will also undo any mods previously applied to the services.jar) (Thanks ihtfp69 for helping me out with this)
For All Themes Except Vanilla
For Vanilla Theme ONLY
StatusBar Mods(Affect services.jar)
Restore Stock
No Battery
No Clock/Battery
No Clock
No Clock w/ Visible Alarm
Unhide Alarm
Remove/Restore Sense
Remove
Restore
Alternate Fonts
Stock Font
Battery Mods (Note: These are MetaMorph Themes and you need to download MetaMorph by Stericson from the Android Market)
Stock Battery
AndyGreen Battery
Droid Battery
Blue Battery
Gingerbread Battery
Gingerbread Battery (Big Numbers)
Cyan Gingerbread Battery (Big Numbers)
MultiColorCircle Battery
WarmZ Battery
Speedo Battery
Cyan Battery
AloysiusBlue Battery
AloysiusGreen Battery
Blue Battery (Alt)
Bright Orange Battery
Gray Battery
Mik Battery
Orange Battery
Purple Battery
Red Battery
Red Battery (Alt)
Vanilla Battery
Upright Battery (Thanks tsoms)
Miscellaneous Mods (Note: These are MetaMorph Themes and you need to download MetaMorph by Stericson from the Android Market)
Clear Pattern Lock
Riptide's Status Bar
Flat Black Titlebar
Transparant Titlebar
Remove Branding From Pull Down
Stock Green 6 Bar Signal
4 Bar Signal
Mods continued.....
Rosie Mods For v2.3
Widgets (Note: If you want to use a 4x5 Rosie you MUST flash the 4x5 Widgets before flashing the Rosie mod
4x4 Widgets
4x5 Widgets
4x2 Agenda Widget
Stock/Gingerbread
Vanilla
Cyan
Blue
Pink
Purple
Red
Orange
Phone-Normal-Browser
4x4 Workspace
4x5 Workspace
Stock HTC (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC Cyan w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC Blue w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC Green w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC Red w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC Orange w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC Purple w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
Stock HTC Pink w/ App Drawer Middle (Right Remappable) (Note: If you flash this and then choose to go back to a different rosie you must also push the original com.htc.resources.apk or else there will be an overlap)
4x4 Workspace
4x5 Workspace
MetaMorph Right Icon Change For Stock Colors Above ONLY!!!!!
Browser
SMS
GMail
GTalk
Clear-Clear-Clear
4x4 Workspace
4x5 Workspace
Phone-Normal-SMS
4x4 Workspace
4x5 Workspace
Phone-Normal-Gmail
4x4 Workspace
4x5 Workspace
Phone-Normal-GTalk
4x4 Workspace
4x5 Workspace
Phone-Normal-GVoice
4x4 Workspace
4x5 Workspace
Phone-Normal-Mail
4x4 Workspace
4x5 Workspace
Phone-Normal-People
4x4 Workspace
4x5 Workspace
Phone-Normal-Settings
4x4 Workspace
4x5 Workspace
iPhone-Phone-App-Browser
4x4 Workspace
4x5 Workspace
iPhone-Phone-App-Facebook
4x4 Workspace
4x5 Workspace
iPhone-Phone-App-SMS
4x4 Workspace
4x5 Workspace
iPhone-Phone-App-Gmail
4x4 Workspace
4x5 Workspace
iPhone-Phone-App-GTalk
4x4 Workspace
4x5 Workspace
iPhone-Phone-App-Mail
4x4 Workspace
4x5 Workspace
MikFroyo-Blank-Phone-Blank (with Text)
4x4 Workspace
4x5 Workspace
Gingerbread
4x4 Workspace
4x5 Workspace
Myn Rosie (Wide)
4x4 Workspace
4x5 Workspace
Myn Rosie (Close)
4x4 Workspace
4x5 Workspace
SexyBread Phone-Arrow-Browser
4x4 Workspace
4x5 Workspace
SexyBread Phone-Arrow-SMS
4x4 Workspace
4x5 Workspace
SexyBread Phone-Arrow-Mail
4x4 Workspace
4x5 Workspace
SexyBread Phone-Grid-Browser
4x4 Workspace
4x5 Workspace
SexyBread Phone-Grid-SMS
4x4 Workspace
4x5 Workspace
SexyBread Phone-Grid-Email
4x4 Workspace
4x5 Workspace
HTC Lockscreens (Note: These are MetaMorph Themes and you need to download MetaMorph by Stericson from the Android Market) (Note: To enable the HTC Lockscreen, navigate to "system/app" using root explorer; Find "HtcLockscreen.bak" and rename it to "HtcLockscreen.apk" and then perform a Hot Restart)
HtcClockWidget w/o DeskClock Button Remap (Flashable)
4x4
4x5
Stock Lockscreen
Black Bar Lockscreen
Carbon Lockscreen
Clear Lockscreen
Float Lockscreen
Myn Lockscreen
Various Mods/Addons (Flashable)
Stock HTC_IME
HTC_IME Mod "Domo Keyboard"
EVO HTC_IME (with arrows)
Custom Transition Animations (Note: These are MetaMorph Themes and you need to download MetaMorph by Stericson from the Android Market)
Bounce Animations
CM7 Animations
Flip Animations
Fly In Animations
Fold Animations
Mix Animations
Myn Animations
Riptide Animations
Stock Animations
Twist Animations
Up Down Animations
Rosie MetaMorphs For Use When Flashing Theme (Note: These are MetaMorph Themes and you need to download MetaMorph by Stericson from the Android Market)
Normal Rosie (Pick the layout you want) (This will only give you the base and left and right buttons, you have to proceed to another step to get the correct color for the app button)
Step 1: Layout
Browser
SMS
GMail
Mail
GTalk
Settings
Step 2: Color
Blue
Cyan
Green
Orange
Red
Purple
Pink
Only one step necessary for these
iPhone Rosie
Browser
SMS
GMail
Mail
GTalk
Facebook
Clear
Myn Rosie
If you are unsure what is what here just unzip the files and look at the images so you can see what you are pushing you your phone.
Themes
Themes for v2.3
Thanks to aamikam for making this possible and coming up with the idea.
Thanks to neur0tx and suprafreak for screenshots and testing these things hard to get all of the kinks worked out of them.
Flash Theme Update AFTER you flash the full theme!
Themed XDA Apps HERE!
Cyan Theme
(More Screenshots can he found here)
4x4
4x5
4x4-02-26-11 Update
4x5-02-26-11 Update
Blue Theme
4x4
4x5
4x4-02-26-11 Update
4x5-02-26-11 Update
Purple Theme
4x4
4x5
4x4-02-26-11 Update
4x5-02-26-11 Update
Pink Theme
4x4
4x5
4x4-02-26-11 Update
4x5-02-26-11 Update
Red Theme
4x4
4x5
4x4-02-26-11 Update
4x5-02-26-11 Update
Orange Theme
4x4
4x5
4x4-02-26-11 Update
4x5-02-26-11 Update
Stock HTC Sense Theme
4x4
4x5
Vanilla Theme
4x4
4x5
Gingerbread Theme
4x4
Chingy, nice work as usual and welcome!!!
It is good to see you over here and I am sure everyone who loves your ROM's will be happy about it as well!!
As per OP it's obvious this ROM is in a class all by itself. If your into tweaking and pure unadulterated speed give this a ROM a go...you won't be sorry.
Thanks chingy!
What's good Chingy! Welcome to AF. You really out did yourself with this release. Congrats bro and thanks again
yeah there is a download on the first page of his post at xda with the htc_ime falshable zip.
Love this rom, looks awesome runs awesome. I'm not seeing the "redonculous" battery life some folks are claiming but by all means I am not bashing it, it seems like it might stabalize and be pretty good when everything is done syncing and I actually put it down for a while.
I couldnt get my wma's to play, so i converted them all anyway not gonna pester on that one and the TV out cable from HTC didnt seem to do anything? I'm hoping there is a flash for that that I missed cause i do use that occasionally and dont really want to have to flash to a different rom to use it.
If neither of those things bother you....this rom is fantastic, no force closes everything syncs, it just works.
I really like this rom, super quick and responsive. Two issues i'm having. One, when trying to restore apps with titanium it force closes after installing one app. does it wether i do one at a time or try to batch. I fixed permissions in rom manager, but still has the same problem. My other issue is when i try to flash a mod (circle battery and myns lock screen so far) nothing happens.
Any suggestion on a fix would be welcome.
Even with these issues I love this rom and plan to keep it for quite a while.
Just rooted and love the rom so far. Thank you for all your work. I can not get hulu to work. It says it is not compatable with my flash player. What am I not doing right?
Ahh Snap Chingy I didn't realize u made the thread here, welcome sucka!
Gotsta up date dem pictars lol
People give this Rom a run if u get some time
really liking this ROM but is there a way to theme or otherwise change the colors for gmail? I'm not liking the black/gray, hard to read. thanks.
Anyone have help on hulu?
My hulu works fine I've never had a problem with it on 2.2 or 2.3.
I only used it a few times as hulu isn't my thing really but it works.
Have you by any chance done a Titanium restore with apps and data? If so just do the apps and don't do any Flash restores.
This goes for others having issues. I have seen more trouble caused by Titanium restores than anything else with custom ROM's. You really have to be careful and pick and choose what you restore....otherwise it's a bugger to try and narrow down issues
I've gotten over 36 hrs on one charge with this rom without juice defender. Battery only down to 29% at this point.
I'm with you this is the only ROM/kernel (Lou's #8) combo that gives me 2 full days with a charge on the TP2 1500mah battery.
Ok,I have flashed quite a few rom's without issue but when I try and flash any of these I get an error-
"Amend scripting was deprecated by Google in Android 1.5,Please switch to edify scripting to create working update .zip packages"
I am sure someone here knows how to overcome this error?
dying to try this ROM.Speed and battery life,what we all need!
OK,I answered my own question.The latest version of Clockword Mod Recovery supports a different kind of scripting.I wiped my phone,re-installed ROM manager,selected the option within ROM manager to flash to an older version and I am flashing the ROM now.(After wiping data,cache,and davlik first)I was able to flash SkyRaider with the updated ROM Manager.I imagine eventually all custom ROM's will support the new scripting but until then I would deny the ROM manager "upgrade".
