Rxpert83
Dr. Feelgood
Hey all, I've been using this for the past 2-3 weeks and I must say its awesome.
This is originally FERBIES but he has let swiper port this over to the EVO 4g for us.
Damn near everything works (except 4g... FERBIE says hes working on this for us though
). One of my favorite features is the dual signal icons, which shows you both your 3G and 1X signal strength so even if your 3G connection sucks you can know you won't drop a call if you have 1X.
Note: For those of you flashing kernels this ROM does NOT have HWA. Make note of that. I'd suggest the Mason Kernel.
For those new to MIUI
Follow the thread on XDA:
http://forum.xda-developers.com/showthread.php?t=1493631
Full changelog:
http://miuiandroid.com/community/threads/miui-rom-2-4-6-changelog-ics.16064/
FIXES:
Other recommendations:
Vipermod -50 (if your phone can handle it)
COD tweaks
There should be an update tonight, so I will be sure to post that up as well.
). One of my favorite features is the dual signal icons, which shows you both your 3G and 1X signal strength so even if your 3G connection sucks you can know you won't drop a call if you have 1X.Note: For those of you flashing kernels this ROM does NOT have HWA. Make note of that. I'd suggest the Mason Kernel.
LBE Guard is you new SU app. It comes with root permissions disabled by default so you need to go in and allow root access before you try to run any root app or it will tell you your not rooted
Full changelog:
FIXES:
USB Mount fix:
[APP/Hack] USB Mass Storage for Ice Cream Sandwich [v.1.2.0-pre - 02.02.2012] - xda-developers
Sprint VVM fix:
[APP ] ICS/CM9/MIUI- Official Sprint ICS Visual Voicemail LINK
Camera fix (if you dont do this the camera will only work at 3MP):
download Camera ICS from market here
Other issues: Dt A2SD will give issues unless you move the CACHE to the SD card as well:
su
A2SD cacheSD
Sprint VVM fix:
su
A2SD cacheSD
COD tweaks
... been running mik3.0 for a loooong time now and need a change... thought this might do until tommy drops his latest....
