Root [ROM][MS870] hybrid MIUI V5 ROM
GT, I'm trying to wipe user data/cache under CWM v6.0.4.4 to change roms and I keep getting "E: unknown volume "/sdcard/ .android_secure"" Now I'm stuck using MIUI because the system cache can't be wiped. Any idea what's causing the "unknown volume"? Never had this problem before. Thanks!
The problem is with the version of CWM you're using. I'm using CWM v6.0.3.9 which works flawlessly on the Spirit.
You should be using the flashable zip in PG's CWM thread found here...
http://androidforums.com/spirit-4g-...lockworkmod-recovery-lg-spirit-ms870-l1m.html
Any problems you have with CWM should be posted in that thread.
Thanks GT,
Yea i got that version from the PG's Handy Dandy installer app. Do you have another link? the one that PG posted is down.
