Root [ROM] MTDEV-CM10 build 20120825 [ALPHA]
G
g60madman
Guest
Image by: CornfedChris​
README:
Welcome to Cyanogen Mod 10! This ROM will be developed by the new improved MTDEV Team.
THE TEAM:
MTDEV started small but just recently got a lot bigger. Rukin5197 and BSydz have both joined into the team to make our Team even stronger. We also added b_randon14 to help with the fun, just need to find him first :D Together all of us will be working to improve CM10 and keep the Motorola Triumph Alive and well! And here everyone thought all the DEV's left...you better think again!
MTDEV would like to thank IssacJ & Tickerguy for getting the ball rolling with Cyanogen Mod Development. Can you believe it CM7, CM9, and now CM10? We would also like to thank Mantera for all his hard work on getting a lot of the pieces together in the puzzle for Jelly Bean. Also without Rukin5197 and BSydz working hard on the code it would not be where it is!! Also MTDEV would like to thank Lloir, and JMZTaylor.
KNOWN ISSUES
∙ 3G
∙ Camera
∙ GPS
∙ Headset
∙ HDMI
∙ Tethering (USB)
∙ Themes in Settings gives a FC
∙ Music Playback
∙ Other......
KERNEL
∙ Mantera's iOCv1.2.2 / 2.6.32.59
ROM ALPHA INFO
This ROM is HIGHLY ALPHA and should be treated as such. Since the code is still in development by the Cyanogen Mod Team many bugs may arise outside of the listed "Known Issues" above. So we ask you to please be patience with the process and know that we are aware of the problems. Posting regarding these issues is not necessary. We thank you for your understanding and patience :)
DOWNLOAD
MTDEV CM10 Rom Browser
INSTALL:
Follow these simple instructions if you’ve never flashed a ROM on the MT. If upgrading from a previous CM9, it is HIGHLY recommend to always do a full wipe data/factory reset & advanced -> dalvik-cache in recovery mode. If you simply wipe both caches and install the ROM you will be carrying over parts of the last ROM. If you need to carry over settings here is a written guide [Guide] How to Backup and Restore Apps and Data when installing new ROMs. Android Market/Play is not included for legal reasons, you MUST flash gapps.zip.
DONATIONS:
Your donations are very much appreciated. All funds are strictly used to help better MTDEV releases be that website or workstation upgrades for all Team Members
DONATION STORIES
Chairshot - Dell T5400 (2) Quad Core 2.0Ghz (8)GB Ram
dsmryder - Dell T5400 (1) Quad Code 2.0ghz (8)GB Ram
g60madman - Dell T5400 (2) Quad Core 3.16Ghz (8)GB Ram
With out the support of our great community none of this would have happened. MTDEV would like to thank all those that have donated to the cause!!!
This is freakin awesome! I knew it just needed to stay up top. And now everyone is involved. In no time at all the triumph will have jelly been! This is just another observation cause I really don't know what goes on...I still feel like there is to much focus on these other roms. I mean cm7 is almost perfect and no one even uses froyo. I'm just saying. It's just a thought cause I don't know what goes into making these roms. Anyways....YES, jelly bean!!!
I feel a little like this is an episode of the original Star Trek & Kirk is telling Scotty "I need more power!" to which Scotty replies "She's givin' you all she can, cap'n!" :)
You guys are amazing..."going where no Triumph devs have gone before."
It's easy to say we should stop development on CM7. However working on CM7 is very easy, a lot easier than CM9 and CM10 as the code has changed so much in ICS/JB. However a lot of the changes and bugs we fix in CM7, can slowly be ported into CM9 and CM10. Also CM7 has the only working camera right now so I think a lot people still use that ROM including myself. Once we get a working camera in 9 hopefully we can port it into CM10.
Also I have some updated code for CM9 for the cameraHAL however it doesn't work including our old GPS code in CM10. It's going to take time to to get CM10 fully working as it will need a kernel upgrade including CM9. While this is a first look at an early alpha it's going to take many man hours to fix everything. Even our old headset hack that we used in CM7 and CM9 does not work in CM10. It's going to be a very slow process to get this to be a solidified daily driver.
This is an awesome start, but you guys are right this is very buggy. Screen is very flaky for one thing. Thanx for keeping thtTriumph alive!!!!
Would love to try this out, but sadly headset not working is a deal breaker. I use my phone to listen to podcasts all day at work :(
DONATIONS:
Your donations are very much appreciated. All funds are strictly used to help better MTDEV releases (website, workstation upgrades, etc. for all Team Members!)
DONATION STORIES
dsmryder - Dell T5400 (1) Quad Code 2.0ghz (8)GB Ram <---
I have two processors, I'm in a holding pattern for the heat sink for the second processor, but eather way, thank you guys who have made the transision easier.
Updated build with latest build BSydz did. Video drivers jitter is gone so its actually usable now. You will need to reboot to use WiFi. Still buggy but getting better!
Awesome work guys. This build is mostly stable.
Just two things I noticed:
Apollo doesn't seem to be working and google now doesn't seem to want to connect. Not complaining just mentioning. You guys are doing an awesome job!!!!
Man, I was just messing with CM10 and was searching the play store for a diagnostic app, and found this: https://play.google.com/store/apps/details?id=com.electricsheep.asi I haven't had a chance yet to look through it all but it gives model numbers and everything for almost every piece of hardware in our phones, just need to run it on stock to see if we can track down all the hardware. Just figured I'd throw this out there.
