Root [ROM] MTDEV-CM10 build 20120825 [ALPHA]
Hey is there anyway to apply the newest upgrades (camera working) from CM9 and get CM10 rolling? Im sure I could get moving if someone was able to show me where to get started.
Thanks
I can get you started. The fixes would still be hard to do, though. You can have at it. I know bSydz and Rukin have made some headway, but it has been a tough road.
bSydz and Rukin, can you guys post your most recent work on CM10? How does one go from a cyanogenmod Rom and format it to even be able to run on our phones? If its easy enough perhaps we should grab the latest 10.1 and run from that. What do i need to do to be able to run 10.1 on my phone? Is there a compatible phone on CM that is similar enough to ours?
Thanks
Thanks
All my latest edits are on the github
I believe I have it booting and everything working, but porting over the camerahal and the data fix are still WIPs
My main question is how do we go from CM10.1 and put it onto our phone?
you need to port over the code to work for cm10.1. Right now, I have everything building for 10.1, but it needs some kernel work done. It has a flashing black screen on bootup that I can't get a logcat for. So as of right now, it's not in a usable state. Might need more time, or might not even come to the triumph in its lifetime. Who knows :confused:
so is are they still working on CM 10?
Well, the CyenogenMod team is, but not for our phone. The further we go, the harder it gets as the code has to be made to work with our device files and kernel. ICS and JB use updated kernel so we have to force the code to work with ours, a modified one for FroYo.
