For some reason when I call out it's taking 25-35 seconds before the call actually connects... anyone else having this issue? Calls in are fine.
Yes this has been happening with me too
My wife's OV is also having the call issue. They must be having some call setup issues. Of course they won't post anything on their site about it. Bad Press.....
One word G60............Awesome! I've got.the 10-25 version installed on my Triumph. So far it's great:thrasher::thrasher::thrasher::thrasher:G60 has.rocked the Triumph and now the encore will be the camera![]()
I'm having the same issue with wifi hotspot, using the 2012-10-25 rom, everything else runs great, super snappy, I turned on wifi hotspot it locks up on tuning on, wifi works fine otherwise here is the logcat, or at least so I hope
http://pastebin.com/embed_js.php?i=Yd1bnZ06
thanx for making this amazing rom
@ Mad man and the MT Dev team, i have been doing alot of reading on the qualcom processors, trying to get some of my geek friends to give up some info. From what im hearing, you gotta switch the base chip to be able to upgrade hardware to a duel or even quadcore. Now that would make this 1 damn fast phone, one of my hardcore M Droid friends said it should be possible:]:} android isnt like windows where you can hyperthread a bazillion windows. Why would we need all that processing power? Unless your a DEV. KEY LIME PIE EHH? First ive heard of it thats why I love Our little MT DEV section here!! More Peeps you got using it, and knowing what the next big thing is def helps. Hardware is just as important as Operating system software!!
If we ask for it SOMEONE WILL MAKE IT!! IDONT WANT A DROID RAZR HD MAX shoved down my
throat!!!
Oh Yeah 10/25/2012 is the best best yet, installed lightning fast . been usuing it since noon, No issues thus far.
Did anyone notice g60 snuck a wimaxx button?
Omg 4G that seems to be working dayamn.
I'm surfing the web and downloading @ lightning speed
And I'm over my data cap!!!!!
Sweeeeeeeeeeeet!
So I came across an extra MT, I had been hesitant to flash cm9 on my daily driver because of the camera. Now that have an extra I just flashed me sum cm9 goodness! All I can say is WOW! So fluid & so smooth! Great job MTDEV Team!! Totally crossing fingers fr that day the camera update comes along!! Im on MTDEV CM7 on my connected MT. How do I get thisort of smoothness out of it?
Where is the wimax button?
Even if the button is in there (I would have no clue where) it shouldn't work as our hardware does not support wimax. It's only Rev A
Evolution-Data Optimized - Wikipedia, the free encyclopedia
I love this ROM so far. great work, runs smooth and all, but how come the audio is so quiet?
I did. I even maxed out literally every equalizer band on either DSP manager or poweramp (not at the same time) and neither was as loud as it should be. ill keep trying to find ways to boost it but for right now i'm stuck with my nano i guessMy audio is good. Make sure that you raised the levels in System Settings>Sound>Volumes
In 20121025 the proximity detector doesn't turn the screen on when I take the phone away from my ear during a call. I have to hit the power button to bring the screen back so that I can end a call.
Sorry if this has already been discussed.
One problem I have is the kernel allows over locking to like 2.2 MHz but when I set mine to 1.9 it sets but defaults back to 1.6 as soon as screen is locked...any way to fix this...or does kernel require changes to fix?
It does that sometimes even in cm7!
