I think if you go into "Settings" when you can (try a reboot) then "Display" and turn on "Auto Adjust" for screen brightness and then turn it off the buttons should stay lit. This will need to be done after each reboot if I remember correctly.
anyone else doing alot of battery pulls with this rom? keeps locking up, not overclocked.....
for me the home button is working.............like theres haptic feedback..but it doesnt work. help?
the only issue I've had so far is Pandora does not work at all for me on this rom, It will load start to play on song then, go in a never ending loop of loading songs and skipping to the next as soon as it does. anyone else having this issue?
I love this rom so far. I've noticed it seams to be more of a battery hog than the MIUI rom I came from.
also when I used CM7 on my OV it used to have an option to make the volume buttons be track previous and next with long press, is there an option in this CM9 for that I didn't see it in the settings?
Yeah just go into settings, then select sound, now scroll all the way to the bottom and you should the "volume rocker music control".![]()
so is this working already camera and everything?NEW FEATURES
08/11/2012
∙ Updated code to CM9.0.0 Stable 1st release
Wow I reflashed and this Rom is super smooth...... Sleeps really well too
Is this a significant improvement from mantera's CM9 alpha yet? I'm quite happy with that ROM as it stands.
Thanks for the work, devs!
is the camera working on it?
I am not sure if this is worth anything here, but I thought that I would mention it anyway. I recently got a Samsung Galaxy Tab 2 which I flashed CM9 on. Well I went to use the camera and it kept force closing on me. Well what I did was use root explorer and deleted the camera app that came with the ROM and installed the ICS camera app from the market. Now the camera works without issue. I know that the issue with the MT camera probably runs deeper than this, but this may be a quick fix for the camera on our phones when the devs get it working and if it keeps force closing.
it doesnt fix anything for us, also camera doesnt force close...it doesnt connect...
