g60madman, could you go into a brief technical summary of what is going on with the camera and what are some of the other technical challenges that you guys are faced with with this particular rom? Also, i noticed you said the hdmi code was included in cm9? Could you elaborate on why it wasnt in cm7, why its in cm9, and some of the technical challenges surrounding getting it to work properly?
I'm confused about this necessity for space for Google. Do you need space to run it?
yes u do need room to run it with their files. u dont need it, but hey its google now! who wouldnt want it? its so convenient
I'm working on the idea for the space issue. There's a hidden partition that the factory used. It's about 80MB, but there's about 20 left if we don't clear it out. On top of that, the new rig I got isn't set up just yet and I can't try anything pragmatically. I hope to have that fixed tonight. And thank you to the community! With your help, I was about to afford this machine that should make getting work done way more efficient. And help keep ideas flowing.
The only problem with the "hidden" partition is I want to make sure it is reversible. I know it can be hard to get down and dirty with the system. And there is a real chance to ruin things of one isn't careful.
well thats great knowing we have a hidden partition. that will make things a bit easier for many other users. let us know how this goes.
Couple more issues I found:
Wifi doesn't auto-connect
Data spends more time as 1x vs 3G. Dunno if this is something specific to this build, however it seems to have been happening since flashing to this from CM7
Thanks for all the hard work!!!!
I can say that my wifi auto connects. At least on most access points. The one where my wife works if kinda flaky for me. As for the mobile date part, outside my corner of Florida, I have been having crappy data service. Voice seems just fine, just data. And it's the data that makes the GPS work so well.LOL.
On top of that, you may have corrupted data from the old flash, a bad flash, or a few other things that aren't ROM related. I would consider a nandroid backup and a reflash.
Right now each build takes roughly 35 minutes and if it doean't work we make tweaks to the code and try again. This is the work of all developers. I would love to tell you there is a big manual sitting on a shelf that has all the answers but that is not the case. Its simply trial and error, and sadly more error and fail than you know. If you have more questions please feel free to drop a line.
will a Bluetooth gps receiver work on this rom? since everyone knows the one built into these doesn't work well.
btw.. battery life seams to improve overtime with this rom, it sucked for me for maybe the first day but after that it was better than I've had with any rom, maybe the battery level just needs to re-calibrate.
also Pandora which i initially had problems with started work both on wifi and mobile data. This is by far the best rom I've used, and probably the best out for the Triumph. I do hope the camera gets working though.
GPS will rock on the next update, we will be adding our GPS fixes from cm7. Don't worry we have been focused on the camera, we want it just as bad trust me![]()
Has anybody had trouble with chrome on either 0811 or 0816 builds? I just flashed each from a complete format, and chrome was the first thing i tried, but it always dies after a little bit too much scrolling on, say, a desktop-size page like dustloop.com; not a complete loss since there are other browsers, but is this problem to be expected? I don't know much about the stability of Chrome on ICS on other devices.
Otherwise, I like this ROM a lot. It's outstanding, though i miss having a torchlight.
You think? Is it possible that maybe you could help contribute to something instead of having silly posts spamming up pages everywhere?no camera = no flash![]()
