Root {rom} oppo_real rom for a75
drdogautam
Complete OPPO ROM without any bug is here:
no description etc....try n see :) ..
direct link of Oppo Real ROM, perfectly working on A75.....
Added Google Framework and apps.....
Play Market is very fast in this ROM...
also some surprises are there in the ROM......
FEATURES:
* long press "menu" will take screenshots :) no need to install other app.
* U can lock a program of ur choice to make it un-killable.
* lots of wallpapers to choose.
* OPPO launcher is die hard, no need of supercharger script. :)
* dialer is fast, no lag.
* Privacy protection feature, u can password protect ur SMS/Call log/Contacts/To do list etc.
* enable or disable 3G service via single button.
* Dolby sound in default music app. :)
bla bla.........
credit: Saivignesh for editing boot.img
Download ROM:
https://adf.ly/REsvR
with init.d scripts and build.prop editing , it is fastest rom. :) try in give me feedback.
For those,who r facing installation abort problem:
unzip the ROM and unzip meta-inf (download from the link : https://adf.ly/REt0k META-INF - Download - 4shared - subhash gautam[/URL] ) then delete meta-inf folder in ROM ZIP and place new meta-inf in the folder and re-zip. now put file on SD Card and flash.
OPPO THEMES:
https://adf.ly/REt8u
https://adf.ly/REtOA
Download ROM: OPPO_ROM_SGautam - Download - 4shared - subhash gautam
yess plzzzz provide some screen shotsss.....
hello brother..
already I used this oppo rom in my spice mi350n with help of saiviganesh...
but network problem of second sim....have u met this problem...
ok..anyway to take effort this rom...
hello brother..
Hi bro i want to use this rom in my Spice mi 350n.Can you pls help me:)
hello brother..
bro just copy modem. img from any spice rom from to this one
Installation Aborted is showing when flashing via install zip from SD card
Thanks in Advance
what error u got? toggal signature verification in CWM Recovery.... then flash the ROM....
nice UI....
hello brother..
u need to flash latest baseband of spice350n i.e. modem.img :)
i have flash June 2012 baseband of A75 and no problem in both SIM's. clear sound during call and full network in both sim.
Dear Gautam
As you told
Toggled Signature Verification then flashed..
But it was showing following error
"E:Signature Verification Failed
Installation aborted"
Agained Toggled Signature Verification & then flashed..
But Then it was showing following error
"E:Error in/Sd card /OPPo_ROM_Sgautam.zip
(Status 6))
Thanks & regards,
Bala
Dear Gautam
As you told
(Status 6))
Thanks & regards,
Bala
I am also facing the same problem...pls help
I found that the sound in the loud speaker is a low anyways i have made a volume fix with mixing some files and it is working great on all other ROMs will try it on this ROM and if it worked will upload it and provide the link for it.
hey actually that dolby sound is good on earphones
Yup but what about ringtone as if while travelling in a busy traffic u need the phone to ring louder so that atleast u can hear the ring and should not miss those important calls correct.
hey guys, one more question how to uninstall the some of the inbuilt junks(as per my opinion), i tried with links2sd but it asked me to turn on the "usb debugging" ,but seems we can't turn on the usb debugging in this rom? do we have anyother way to uninstall the junk apps ?
use titanium backup....... or connect phone with PC via USB then select ON for "usb debugging"...... after connect with usb cable u will b able to uninstall apps.
FEATURES:
bla bla.........
unzip the ROM and unzip meta-inf (download from the link : META-INF - Download - 4shared - subhash gautam ) then delete meta-inf folder in ROM ZIP and place new meta-inf in the folder and re-zip. now put file on SD Card and flash.
hai plz provide resumeable link
