Complete OPPO ROM without any bug is here:
no description etc....try n see
direct link of Oppo Real ROM, perfectly working on A75.....
Added Google Framework and apps.....
Play Market is very fast in this ROM...
also some surprises are there in the ROM......
FEATURES:
* long press "menu" will take screenshots
no need to install other app.
* U can lock a program of ur choice to make it un-killable.
* lots of wallpapers to choose.
* OPPO launcher is die hard, no need of supercharger script.
* dialer is fast, no lag.
* Privacy protection feature, u can password protect ur SMS/Call log/Contacts/To do list etc.
* enable or disable 3G service via single button.
* Dolby sound in default music app.
bla bla.........
credit: Saivignesh for editing boot.img
Download ROM:
OPPO_ROM_SGautam - Download - 4shared - subhash gautam
with init.d scripts and build.prop editing , it is fastest rom.
try in give me feedback.
For those,who r facing installation abort problem:
unzip the ROM and unzip meta-inf (download from the link :
META-INF - Download - 4shared - subhash gautam ) then delete meta-inf folder in ROM ZIP and place new meta-inf in the folder and re-zip. now put file on SD Card and flash.
For Resumable Links, Use the mirror provided by jana7418:
!EmbedUpload.com - upload your files to multiple file hosting sites
OPPO_ROM_SGautam.zip Download - Directmirror.com - Upload & Mirror your files!
Already I Added Multiple Mirrors Just Above Your Post....
