Root {rom} oppo_real rom for a75
cant use facebook and friendcaster...they r closing when i m trying to scroll down..flash light apps also not working...plz...help..
yes data2ext will work in this rom too...but for that u have to flash data2ext zip given by mastermind.
@Gautam & Mastermind
OPPO Rom Running Smoothly except insufficient Internal storage
Actually I am having 2nd partition in SD card for 2GB.
It was showing in link2sd also.
But If i flash data2ext.zip by mastermind there is no improvement in Internal memory.
And there is no Format/sd-ext Option in CWM recovery mode in mount & Storage. The Data2Ext zip flashing requires Format/sd-ext also thro cwm.
Pls provide us the detailed procedure for making data2ext working in this OPPO Rom. Because As u know internal memory is too low for A75.
for usb debugging to b alwAys ON,
edit 'persist.oppo.adb.alwayson=no' to 'persist.oppo.adb.alwayson=yes' in build.prop ...
restart ur phone.. enjoy... :)
flash mastermind's cwm it has the format option in mount and format and then try mastermind's data2ext. if again u find the same problem then try int2ext by mastermind..it will surely work..:)
