omgbossis21
Couldnt get it to download on the desktop but got it off the wifes laptop. Love the rom so far, thanks so much! The overclock is such a great feature, 729mhz and Im good to go =-)
Ladies and Gentlemen It's here the rom zero final.
So what's this rom all about? Let me tell you
First this rom is only for the guys that had 2.2 and can flash 2.2 roms
LOL these forums are what he song chocolate rain meant
This is for phones with 2.2. There is a RomZero for 2.2.1 but it does not have the ability to be overclocked.Is that yes or no? I'm just asking because I know there is a difference between 2.1, 2.2 and 2.2.1 which I have.
Well after some internet issue, I see that we may get a Rom Zero III? If so maybe I'll wait it out. I have been considering changing up Roms of late.
It seems as though Asadullah will release another version. I'm looking forward to it. The other ROMs look fine and the people who cannot overclock are happy. I like the stability and flexibility of ROM Zero and I will not bother flashing anything else until a newer version of ROM Zero comes out or something that has the same properties comes out. I like this ROM and I haven't looked back and I only considered the new ROMs for about 30 seconds. ROM Zero sets a standard.
will this work if i updated my phone to 2.2.1 from 2.2?
So how do I go amongst making the naindroid backup? Grab naindroid 2.0 then go into custom recovery and then do it that way? Also i place just the zips inside the "A" folder correct?
That tool is 3 years old.You say to just get Nandoid 2.0 from the market; but I can't find it on the market. Where is it?
You don't need it and I wouldn't suggest trying it.
If you have custom recovery installed, you already have the ability to create and restore backups.
If you don't have custom recovery, go get it!
Installing Custom RecoveryOk, thanks. I've looked at the thread about installing custom recovery, but it confuses me on how to install it. I also posted a question about what adb is, in that thread, but it's not been answered yet.
You are not changing the ROM. You are changing the stock recovery into a "developer" type recovery wherein you can flash/install Custom ROMS, make NAND (aka system) backups and restore same.jabbawest, thank you for helping me with the android sdk. Now, I have another question: what exactly am I doing when I follow the Install Recovery procedures? Am I changing the stock rom on my phone? Am I just adding recovery features to my phone? I'm really leery of proceeding without knowing what and why I'm doing.
You have to have this. Even if you don't wish to proceed with flashing ROMS, you still need this tool to backup the state of the phone as it is right now, which is rooted but still stock.
In the event you decide to return to stock, (probably never will) you will have that NAND backup to restore and then you can unroot.
This ROM was specifically built for Android version 2.2, so be sure you have the correct version before installing. This will not work on 2.2.1I have a new question. What is the Google Apps (gapps)? There isn't a specific app on the market called Google Apps or gapps. I went ahead and down loaded it, along with the ROM, from the op, but I'd like to know what's all in it.
Thank you.
The gapps zip conatins all of the google proprietary applications like gmail, gtalk, etc, etc.
This ROM requires you to install the gapps, some do not as they have the google setup built in which, after setup, you will then download all of these applications.
Correct, you will have to flash the gapps zip immediately after flashing the ROM.So this ROM doesn't have gmail, calendar, etc like the Sense ROM and others do. Thank you for the reply.
