biggiephil
Does this rom clear up any internal space?
Yeah quite a bit
I still cant get this ROM to install, everything flashes fine but it doesn't install, I've redownloaded it many times, I flashed it may times still nothing
Phil, have you made any edits to the zip??What's happening exactly? Try downloading on a computer or different browser and putting on your ext sdcard from computer
I have tried that still hasn't worked. It flashes fines, all the text shows up and it says install finished or something similar, but never installsWhat's happening exactly? Try downloading on a computer or different browser and putting on your ext sdcard from computer
Are you using the MetroPCS MS323?
Yes I'm on metro l70
Weird I will download and try to flash it again
Tried again, still nothingWorked fine
that's weird, I don't know what to tell you man. Others have said it works
thanksNice work it likes to eat up my battery a little but other than that nice job
Jpsantos
One, no it doesn't take that long to install my deodexed rom, second no it doesnt say from external_sd complete.... maybe something has gone corrupted during the process, I will download and re flash it myself now and tell you the outcome.I have tried loading this ROM three times on 2 different brand new L70's (MetroPCS).
I'm following the directions exactly.
1. Create a backup using CWM.
2. Wipe data/Factory reset.
3. Wipe cache partition.
4. Clear Dalvik cache.
5. Install zip.
6. Reboot
I boot into CWM Recovery. The ROM (Deodexed L70 ROM.zip) is on my external SD card.
I select "Choose zip from /external_sd
Then about 2 seconds later I get this screen that says "Install from sdcard complete".
It should take alot longer than 2 seconds. And why doesn't it say "Installed from external_sd complete"?? Because that's where my Rom zip is.
Then I reboot, and its back to my original stock ROM, and I now have to start over and re-install towelroot, superuser, busybox.
Same thing three times. I don't know what to try now...
And yes, I downloaded the ROM to a PC and copied it to the external SD card.
Yeah, looking into the script now, it wasnt, was it?I could be wrong, maybe it was 3-4 seconds.
And also BTW I did check the MD5 checksum to make sure my download was not corrupted.
yea, good. I'm not sure why thats happening just yet...You mean was the download corrupted? No, the checksums matched.
Phil, send me your updater-script in PM so I can check it out for you when I have the time. I have been really busy with school
