MindlessZombie
I downloaded the file from google docs on my phone. It didn't show up on Opera but Skyfire it showed up. Try different browsers.
So, I stand corrected. LOL
Damn, how long did it take on your phone??
You won't be able to do it on your phone. The file is far to large to download with your phone. LOL. Do you not have a connection at your house?
Ladies and Gentleman proudly presenting a themed 2.2.1 Rom that looks like Sense UI.
And other addons and modifications that I hope you people like.
To flash go to recovery, then select wipe and select Wipe All User Data. Go back and now select flash from zip menu then disable signature verify. Then select Flash from zip and look for the downloaded .zip file and select it.
Hope that those quick instructions help you guys
A2sd support: Create a partition using custom recovery to enable a2sd. Make sure that partition is on ext3 format. Make partition before flashing rom. **Backup your sdcard because during partition it gets formatted.**
DOWNLOAD
MD5 Sum: 970C972F9777FF6C528814A2C814B47D
Tested before uploading. Everything works
Thanks to the guys over at XDA Forums
And also thanks to asadullah for guiding me through modifying things.
So, I am trying to run a nand backup but it says error, run in adb. I once tried to restore and got error but that was due to low battery, When I try to run the backup, I have literally 100%battery
Are you trying to run nand + sd-ext in joneidy's recovery?
I got the same error in joinedys recovery but I just did what it said, ran it through adb and im good nowJust nand backup. Joneidy's recovery
Update to the new recovery. It's very easy and it's fully functional. I just did a full nand restore with ext 2 times last night with 0 problems.
im having problems with pairing&connecting bluetooth on my Optimus M, running Sense rom, custom recovery 2.2.1 by joneidy. Any solutions.Ladies and Gentleman proudly presenting a themed 2.2.1 Rom that looks like Sense UI.
DOWNLOAD
