I dont think Im running the latest ver because the bluetooth not working. My download came from the May 14, 2011 post.
I noticed in the change log it says added reboot into recovery etc. in power menu but when I hit power it simple reboots the phone, no menu or anything....just bringing it up for info I use quick boot anyway
I dont use the stock messaging app and neither should youAnyone notice force close when trying to send pic/vid in stock messaging app?
Yes I have. Just something I noticed, Im not gonna re-flash, quick boot is just fine (had to dl it though,I think the first version of this rom came with it but not the latest)I ran into that problem once when I was testing the rom, I forget what else was going on, and I don't have the results of my testing typed out anymore. Dangit! Now I'd really like to remember. The best tip I can think of right now is wipe/reflash the rom. I THINK what I did was in trying to flash a theme, I flashed a faulty framework-res.apk. It was a framework from the last version of sense that had been modified through UOT kitchen.And I THINK how I solved the problem was by recreating my theme with the framework-res from THIS version of the rom.
I could be way off on this. but have you flashed any framework themes after flashing the rom?
I'll re-flash it and let u know the results, thanks.Well he's edited that post. If you go download a version right now from the original post, it's going to be the latest version.
Where is the pole?
Where did u get that custom kernel r.o.c. from?
he said it not me. lol.Huh? You mean because he said "Thanks for voting"? I was gonna make a smartass joke about exotic dancing because you said pole and not poll, but that really is a good question lol.
EDIT: Just found it. Just go to the top of any page in the thread, and it's a two choice poll.
I did use the wrong word didn't I.
Thanks for pointing out that the poll is at the top of the page. I was reading the thread in the phandroid app and didn't see the poll.WOW I have seen like many problems posted on the last 2 days. To all of you the only thing I can say is; download the latest version of the rom in the OP wipe everything and flash it.
All the problems stated above where solved in the last rom updated from July 18, and I can prove to you that I`m running the lastes update and haven`t seen any problems.
PS If anyone is using the lastest update, please vote on the poll and tell me if it has worked for you.
Thanks for voting.
download widget locker from the android market it has custom lockscreens including the cm7 oneanyway to change the lock screen? I like the cm lock screen better =/
Did you partition your sd cardI have been using this ROM for about a week I really love it,No complaints!
But I have a question if anyone can help me out?
I backed-up all of my apps with Titanium Backup before I flashed the ROM.
But after I flashed I went to Titanium Backup(Titanium PRO was on my phone I am thinking it was built into the ROM because I had the free version before the flash) to get my apps back on the phone,they were not in TB,But if I look at the files on my SD card I can see the app files I just can not get them to where I can use them.Can someone please explain to me how to do this?
not if you dont want to but lemme ask this, when you look at your sd card do you see a titanium backup folder (if not then your not backed-up), it should automatically detect it
I had this problem once, Try taking the sd card out and putting it back in.Yes when I look at my sd card I can see a folder called Titanium Backup
