I'll try & make this my last concern because I feel like I've been stressful these past few days lol. I would like to have the vertical, horizontal, cyan (or whatever the color of the rest of the status bar is) battery icon, like Jellybean.
Please help. I'm new to flashing, but I believe everything is being done right.
Virgin Mobile, evo v 4g, using 4ext recovery with smart flash enabled.
I downloaded the file,
formatted everything but the sdcard,
but when I go to install it from the .zip, 4ext aborts the operation and says the file is "bad".
/??? This is the 5th ROM I've downloaded, and the only one I can get to actually load has broken wi-fi coding. I've considered it was a recovery issue (3 of the 5 were PACMAN roms, which never mentioned 4ext recovery in the install instructions)
Please halp! Thanks.
edit: one thing I can think of is the file is supposed to be 317mb, is that UNZIPPED? b/c the file I have is zipped. Will try extracting the file to the sdcard first, and see if I can install it like that.
edit 2---> winrar won't let me extract the file, says the archive is damaged or in an unknown format. :/ guess...I'll try downloading it again?
For starters. What apps do you have installed?
I would also be using 4EXT Recovery
nstagram Video only supports 4.1+ And I've came to the conclusion that no 4.1+ roms on our device support 3D am I right? I'm not planning on leaving this rom I just want to know if there's a way to trick Instagram into thinking I have a 4.1+ Device. I was thinking Market Helper would work but it didn't ): unless I did it wrong lol
it's not letting me download, just redirecting me to an add. And my phone died like an hour ago & now I'm stuck on the boot animation ):
Re-Flash your Rom
and for your troubles Click Here[/QUOTE
Ugh will I lose all of my data? And how do I boot into recovery
