Mobstergunz
Android Expert
looks in the setting on the messaging app
either its a leedroid thing you can change in the app or it an htc lockscreen thing
can you give me all of the links & steps I need? And these are regarding the Handcent SMS issue correct? & can i do it all just from the phone? I only have access to a Mac and you know how complicated that is lol
I'm having a lot of issues with battery life, but I can't figure out if it's the ROM, the phone, or the battery itself. Doing minimal (maybe 25-50) texts and some email checks, I nearly burn through the entire battery in an 8.5 hour work day. I don't use 4G, I don't have any notorious battery hogging apps running, I underclock when not in use, screen brightness/auto-off time is the absolute minimum, etc.
For the ROM: Admittedly, I have nothing to compare it to. I bought the Evo V through work, brought it home, and this was the first ROM I flashed to it. I haven't upgraded the kernel or anything; I'm using what's on the first post of the thread. I'm too lazy to flash another ROM though.
For the phone: I bought it used, but it was in pristine condition and looked like it had never been used at all. When I check what's eating the battery, the main offender seems to be the screen with cell standby and phone idle behind it. No apps are eating much as far as I can see.
For the battery: I have tried two different batteries, calibrated both twice, and it doesn't seem to help. Both are the standard HTC batteries; no China/Hong Kong crap. I keep the other one with me in case I need to switch to it though, that's how bad this issue is.
Do you have any ideas/tips on what I can do? I don't expect some super unreasonable amount of battery life, but I would like to get through a work day where I don't use the phone all that much and not have to worry about it dying.![]()
Have you tried the Save Power option Quick Settings?
Yup. Doesn't affect it one bit.
If you guys are having bad battery life it isn't this ROM. I get insanely good battery life using this ROM.
And others do as well
