Do you swipe to clear them or actually view the messages and whatnot?
Sorry for my wording, i meant to say "the sounds of the notifications"
sorry once again for the confusion.
been using this the last 2 days and it just doesn't seem like it holds up currently, 40%, 7hrs 29 mins on battery. is this average on this rom? because i've seen posts of roughly 10 hrs as average! someone maybe tell me what the kernel tuner is tuned to for such lovely battery?
Gotta be something your doing. Try a fresh install and wipe battery stats. And will some one test out ringtones on mobsters current 2.76 and report back. If they work on his Rom then its something I can fix. It might of been something I deleted
I switched ringtones and rebooted. No issues. It all stays for me, no phone freeze ups or anything.
try redownloading with your computer . not phone.... You might of had a bad download. and make sure you do a factory reset in recovery and wipe cache & dalviknot sure what it is, i installed this rom twice and got same error.. went back to mobsters and dont have it? have no idea why
If you had the same problem on his ROM I am at a lost in how to fix itWhen I mentioned this last week I tried Mobster 2.76 and I had the same problem of ringtones not sticking.
I was able to send a picture message to a buddy of mine using midnight,then i flash your rom and was not able to send the same pic to the same person not sure what's going on.
I would format system data and cache . Then wipe dalvik
Day 3 and I'm really loving it so far. I've been having trouble when trying to hot reboot - it just hangs on the final part of the boot animation. Works fine if I reboot regularly or power off then power back on. Has anyone else noticed this or is it just me?
I've noticed on almost all de-sensed ROMs, even though the icons in the notification bar are the same as stock Holo, the spacing is different and the 3G signal doesn't appear on top of the signal bar like stock Holo. Why is that, exactly?
(NOT a complaint, just a curiosity)
