Had another strange issue with DSP mgr - wouldn't let me uninstall or revert back to system app.. Every time I'd reboot it was back and in system/app. Got it fixed, but FYI
Upvote
0
For Boost Mobile ZTE Warp 4G N9510 only..
Porting this rom to the n9511 is possible. You would need to modify the ramdisk and replace the kernel, modify build.prop, and replace the kernel modules at a minimum to make it work.What is the likelyhood of getting this rom working on the N9511 (aka ZTE Source) which is essentially the same CDMA phone ZTE built for Cricket but with a cheaper, lower resolution screen and lesser camera?
same Krait200 cpu, same MSM8930, same Adreno 305, same 1GB ram
(but supposedly the rom size on N9511 is 4GB vs N9510 8gb)
will the display driver realize the N9511 is 480x854 resolution instead of the warp's 720x1280
Or is there more to it than that like the touch sensor driver?
Most people aren't going to care if the cdma radio and camera do not work on the N9511, only about kitkat stability and performance
other than hroark13's defunct CM11 project, there is no 4.4 available for the N9511
The surge in renewed N9511 interest is because Cricket is dumping the Source phone for $10 all over the internet now since AT&T bought them and retired their CDMA network for GSM instead
It uses a unified kernel source, but each has it's own ramdisk, kernel modules, build.prop, etc. When it flashes, the script checks what device you have and installs the appropriate files.how does a build like hroark13's multi-zte cm11 work on so many devices with a single kernel?
You could certainly try it. It will either work or it won'tI wonder if I could flash this and then flash a 4.1 n9511 kernel over it. Oh wait, the partitions on 4.1 are different than 4.4 aren't they.
Can you please tell me where it is available for $10? I need to buy one.
Just hit EnterSo I burned the .iso file as an img, booted from cd rom but I get I need a slitaz user name and password to login to even do anything....... So it won't work.
Have u tried an IMG stick? (USB) I had a PC once that wouldn't do CDs for some reason but IMG sticks worked fine, and another PC that was other way around..Hey still not working.
Yep. It's in my upcoming JollyRoger ROM as well but you can try this (YES, it works. Guaranteed):So is there a way to use hotspot with this phone
I believe I fixed/figured out the Miracast/cast screen overheat issue: a script I was running for the touchscreen was the culprit. Removed it, rebooted and the device operated universally cooler since then. Even played a game on Miracast for a cpl hrs to check. No superheating & no glitching.FYI. This Warp4G N9510 does NOT like or able to sustain any Miracast connection for very long, as this phone gets so hot that it starts glitching & cooking the micro SD..
Sorry about that. Should have done that to begin with since they were off topic.A couple of posts were move to the following thread where they fit the topic better.
http://androidforums.com/threads/bc...r_4g-and-killerkobalt4g-theme-released.865074
Imagine that.....Bahahah! LOOKIE LOOKIE!!
I'm sure it's NOT Lollipop, that's why I put lol behind it. But yeah your right, something that small is probably just a patch for issues relating to security.Don't think its LP.. Only 13MB.zip.. I'm thinking maybe Stagefright patch & KingRoot patch, Lol. But here's the update zip
https://www.androidfilehost.com/?fid=24052804347838792
