Wizaired
Does this look about right for this ROM bench mark
Seems a little high lol.
so you think this phone with that set up runs better personally, going back to jb?Low. I swear on my life I benchmarked over 40,000! The JB ROM 4.1.2 CDZ OC kernel @1988Mhz
Performance? Yes, but ONLY cuz there's an OC Kernel available. Remember - no WiFi available w/ cdz OC kernel. If a KK OC kernel is made.. Who knows? [emoji41] I mostly used Jim Smith's Jock 1.5 kernel. Real stableso you think this phone with that set up runs better personally, going back to jb?
DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk.
For Boost Mobile ZTE Warp 4G N9510 only.
Completely Unmodified Stock B12 KitKat 4.4.2.
warplte_stock_B12.zip
Debloated and Deodexed Stock B12 KitKat 4.4.2 with Root.
warplte_stock_B12_deodexed_2.zip
/app/Books.apk
/app/ChromeWithBrowser.apk
/app/ConnectionsOptimizer.apk
/app/Hangouts.apk
/app/Magazines.apk
/app/MobileZone.apk
/app/Music2.apk
/app/PlusOne.apk
/app/SpanishPack.apk
/app/Swype.apk
/app/talkback.apk
/app/Videos.apk
/app/WorldTime.apk
/app/xtra_t_app.apk
/app/YouTube.apk
/lib/libchromeview.so
/lib/libSwypeCore.so
/media/bootanimation_sprint.zip
/media/bootanimation_virgin.zip
/priv-app/EmailZTE.apk
/priv-app/ExchangeZTE.apk
/priv-app/SprintID.apk
DOWNLOAD:
warplte_B12_NOT_FLASHABLE_deodexed_removed.zip
NOTE1: If you have not updated to 4.4.2 (B12) via OTA, you should flash this partition updater AND the rom of choice. You only need to flash this once.
NOTE2: Your device must have CWM/PhilZ to flash ROMs.
NOTE3: These zips are unsigned so you will need to disable signature verification in CWM/PhilZ before flashing.
Flash in CWM/PhilZ as follows:
- Download ROM of choice
- Put the ROM.zip on your sdcard if not already
- Reboot to CWM/PhilZ Recovery
- MAKE A BACKUP!!!!!!!!!!
- Wipe data/Factoy reset
- Install partition updater from sdcard (see NOTE1 above)
- Install ROM from sdcard
- Reboot
- Enjoy!
Other Downloads/Links:
warplte_stock_B12_recovery_flashable.zip
warplte_stock_B12_kernel_flashable.zip
warplte_TB_fix.zip - Allows Titanium Backup and other apps to write to the external sdcard
UPDATE-SuperSU-v2.16.zip - Flash this after the unmodified ROM to get root
Root instructions for full stock 4.4.2 devices
Thanks to:
biasporpoise - Uploaded 4.4.2 B12 system files and partitions
Chainfire - For SuperSU
ZTE - For bringing KitKat to the Warp 4G
If Framaroot didn't work then use SuperR's root method for 4.4.2 KK OSIs this all the steps to root the warp 4g from boost mobile? (i just joined this site so i'm new af lol) i wanna root my phone but i know absolutely nothing about it. i tried test driving it out using some different softwares i found online but couldn't get them to work and have no idea whatsoever how to root my phone and i need that extra memory lol.
Look in the first post in this thread. You will see a link toward the bottom that says Root instructions for 4.4.2 devices.where can i find that at in this thread? these forums always have so many pages in one forum it's confusing af...
Root Instructions for full stock 4.4.2 devices
Download the Warp 4G Unbrick tool iso
Download SuperSU.zip and put it on the sdcard of your device
(optional - only if you want to install PhilZ too) Download PhilZ_recovery.zip and put it on the sdcard of your device
Enable USB debugging on your device - go to Settings > About phone. Tap on SW version several times until it says you are a developer. Hit back to get to the main settings, choose Developer options, check USB debugging, agree to the terms.
Use your favorite burning software to burn the iso image to cd. ImgBurn for windows is nice because it is free, easy, and effective. Personally I make bootable usb flash drives instead of cd's. There is a program called Unetbootin that makes the process very easy. Once the cd is burned or the USB flash drive is created, put it in your pc and reboot. Enter into your pc bios and change the boot order making the cd drive/flash drive the first to boot. Normally to get into pc bios, you need to press one of the following: del, f2, f10, or f12. It depends on the pc but it is usually right after the pc starts and it will say on the screen which one to press.
Plug in your device to the usb port.
Open the folder marked My Documents on the desktop
Then choose ZTE_Unbrick_Tool
Right click on partitions folder
Left click on Open in Terminal
(thanks to ghost915 for posting this easier method of getting to the right folder)
Type the following in the terminal:
adb reboot bootloader
(you will need to accept something on the device at this point or it will say the device is unauthorized)
Once you are in bootloader type:
fastboot boot warplte_mmcblk0p16_recovery.img
(this will boot your device into PhilZ recovery. It will not install it, just boot to it. You will have the ability to use it as normal until you reboot)
(optional) Flash PhilZ_recovery.zip like a normal ROM on your device to install PhilZ
Flash SuperSU.zip like a normal ROM on your device. Reboot your device and enjoy root![]()
There are links in the instructions. Where it says to download something, it is a link to the thing you need to download.how do i get the iso image?
No need to format the cd-r. Just use a blank one, use cd burning software with the option similar to "burn image to disk"i can't seem to format my cd-r to burn the iso image to it. suggestions? i've tried burning the iso image using the default burner and the 2 listed above... all three failed...
You don't need to know what a partition is, just follow the instructionsI already know this... i downloaded all three files. i don't know how to tell wtf a partition is.. therefore i don't know how to recognize it.... i've also right clicked on every folder. i don't have the option to 'open in terminal'
You don't need to know what a partition is, just follow the instructions![]()
It needs to be written as an image, not as a data diskdo i actually have to burn the iso image to the disc or can i just copy and paste it on the disc as if the disc was a data disc?
Did you try unetbootin to make a bootable usb flash drive from the iso?well that being said i cant do it. soooo ya.... #Practically****ed..
I found a tutorial on how to burn an iso with imgburn, the windows program i linked in my instructions. Hope it helpsya i tried that one before i tried the other one u suggested... neither worked...
https://neosmart.net/wiki/burning-iso-images-with-imgburn/
