Download PhilZ from this post. Unzip the zip file and put the recovery.img file on your sdcard. Use flashify to install it.How do I do that?..
Are you guys using Eclipse for Android SDK? I'm running Windows 10? I read up on it a little but thought you guys would know for sure. Thanks
Eclipse is for creating Android applications. I have not used it personally as I do not create Android apps. You can certainly run it using VirtualBox, but as with all things virtual you will experience slower performance than you would running it native.And is it possible to run it through Virtual Box on my laptop?
What are u trying to do??Are you guys using Eclipse for Android SDK? I'm running Windows 10? I read up on it a little but thought you guys would know for sure. Thanks
My Noob colors are showing I guess. lol. Do you use any special software or drivers when you put these roms together? I was just about to download and ADT bundle so thanks for letting me know, honestly I was curious how you go about the process.Eclipse is for creating Android applications. I have not used it personally as I do not create Android apps. You can certainly run it using VirtualBox, but as with all things virtual you will experience slower performance than you would running it native.
My Noob colors are showing I guess. lol. Do you use any special software or drivers when you put these roms together? I was just about to download and ADT bundle so thanks for letting me know, honestly I am really curious how you go about the process.Eclipse is for creating Android applications. I have not used it personally as I do not create Android apps. You can certainly run it using VirtualBox, but as with all things virtual you will experience slower performance than you would running it native.
I use Gedit text editor, Linux terminal, and Nemo file manager to create a ROMMy Noob colors are showing I guess. lol. Do you use any special software or drivers when you put these roms together? I was just about to download and ADT bundle so thanks for letting me know, honestly I was curious how you go about the process.
What are u trying to do??[/QUOTE
Nothing specific, was just curious how it was done. I have way too much time on my hands since my bike wreck and was just messing around, but thanks.
Oh alright, thanks. And I appreciate the work on this rom, running flawless on my end.I use Gedit text editor, Linux terminal, and Nemo file manager to create a ROM
I believe I have - not enough towers set up for 4G. If u remember, a good while back all Boost/Nextel/Sprint IDEN towers got shut down for the 4G programming. Most have been useful as a 3G towers but the the 4G Lte rollout isn't complete. Switch it to 3G and watch ur reception jump 3 bars, lol. I went outta town and my bars maxed out by my old place then back to nothing after I left..Has anyone figured out why the signal strength bars show 1 or none?
looks great
I posted a fix for thatshas anyone been experiencing crashes when using the Google keyboard and AutoCorrect both phone so I flashed are experiencing the same issue
lol. Strange they put out an update for a device and immediately stopped carrying itBoost Mobile has now pulled all Warp 4G phones, so you'll only be able to buy used or the few left in Amazon.com like I just had to. My Dumb@$$ woke up the other morning with my phone in my hands twisted and folded like a wallet.. and glass everywhere. Lmfao.. I think maybe the wrong person called me while I was sleeping too hard. LOL
lol. Strange they put out an update for a device and immediately stopped carrying it![]()
Ive been using swiftkey but am switching to google keyboard and experienced the fc issue. Do I just flash this zip wit Philz? ThanksI posted a fix for thats![]()
