sounds about right ZingBotthat should do it just fine and edodson84 where did you get that lock? and anybody figure out how to add widgets to the stock lockscreen? or how to put custom apps on the lockscreen yet?
I saw something about partitioning the SD card in such a way that you create additional available storage for apps. Has anyone tried this?? If so can anyone give advice/instructions on methods for doing it on our phone?
Thanks!!!
NOTE1: If you have not updated to 4.4.2 (B12) via OTA, you should flash this partition updater AND the rom of choice. You only need to flash this once.
NOTE2: Your device must have CWM/PhilZ to flash ROMs.
NOTE3: These zips are unsigned so you will need to disable signature verification in CWM/PhilZ before flashing.
Flash in CWM/PhilZ as follows:
Download ROM of choice
Put the ROM.zip on your sdcard if not already
Reboot to CWM/PhilZ Recovery
MAKE A BACKUP!!!!!!!!!!
Wipe data/Factoy reset
Install partition updater from sdcard (see NOTE1 above)
I'm stuck Idk what to do I'm rooted and my phone keeps asking me to update I would but I don't want to lose root and my Wi-Fi so I can get on my Xbox. I
Remove cwm.IMG if it's in a zip, then hit the Recovery option when u open flashify and select the IMG u want (either cwm or philz) and follow flashify instructions/reboot.
P.s. must be already rooted to use flashify
