check for signal strength and if security fc's since it is one of the partitions from 4.1.2.
OK gotcha. Will do right now...
So the jb modem didn't work?
I had the same problems you have to reflash ROM clear data factory data reset and look in storage in settings you should have a lot of internal space and immediately start installing apps because for some unknown reason when I reboot it shows that Ive used up a lot of space and I hadn't installed apps yet I hopes this works for you.
No it didn't.. I've got lots of space usable but certain apps keep saying I have no internal memory available but the space is there plain as day. I can install /uninstall APKs all day long but not allowed to make backups & whatnot..
@SuperR - is there any chance someone has a full unmodified but completely DEODEXED ROM? I'm having issues that I may have caused myself and trying to troubleshoot/fix but need an unmodified & deodexed ROM.
Here's the situation: whenever I try to upload pics or files online the only options I get are Camera, Sound recorder, and Documents - No Gallery selection or File manager. And I don't know why
You can download the deodexed removed files from the OP and toss them in their respective places in the deodexed rom.
Dude I downloaded 3g 4g optimizer pro from Google play and customized with a 4g preset and I'm getting lte where I didn't get it before.
everything works but wgen i reboot it stays on green android ...recovery will still load
wtfff everything works perfect til i go to reboot..do i need an updated bootloader?
Without the partition updater I had the same problem, but ather flashing the zip the ROM reboots fine now. Thanks super r and team I'm looking forward to you bringing lollipop to the warp 4g LTE.
If anyone wants to revert to 4.1.2, you can use this 4.1.2 partition updater and flash a 4.1.2 stock rom to get back to where you started
