Root [ROM] Warp 4G Stock B12 KitKat 4.4.2 Deodexed and Unmodified
I just tried to swap boot IMG from the super rom port you made for the Max and updater script. The ROM wouldn't install
I'm using the slim deodexed version and I'm having a problem with phone memory. I removed calc, calendar, and a few others. Is there anything else that can be removed ?
I usually trash the Alarm, timer, filer, (but install my own & insert in system) but also noticed that data consumption goes thru the roof for some reason when u do so...
I'm still getting the "running out of storage" error in notifications. I only added maybe five apps from the play store. I'll figure something out.
Does anyone have a script to reverse the partitions ? I wanted to switch back to the 4.1.2
SuperR posted a TB fix zip that changed a permission back to JB 4.1.2 cuz of something to do with "write to SD permissions" and that done the trick for me.. Oh! Also pics in/on SD-0 need erasing too.. (Camera, screenshots, random "SD" & "browser" pic folders that pop up during cam use..) I quit getting "low storage/insufficient memory" notification after dealing with those.. And BTW - most of my system APKs are themed/inverted (MY own doing and flashing other's work) so my APKs sizes are like 3
Ok so I've done some testing and have found that my 3g data speeds are double when only on CDMA mode... When on LTE/CDMA my 3g is like 1x speed... Anyone else experience this???
OK.. I went waaay outta town to even another county and my reception bars are maxed out in LTE mode (first ever). So I'm assuming that my neighboring Boost/Sprint tower doesn't work correctly anymore. I know it's been struck by lightning a cpl times over last few yrs but was always fixed so I'm guessing it wasn't properly fixed the last time? Therefore, I believe there might not be a problem with LTE capabilities in this device and that Boost just hasn't rolled out a more consistent spread of Lte coverage and the tower I'm used to dealing with may not have real Lte yet
This post has what you request
revert to 4.1.2
I did a complete wipe of internal and external SD flashed B12 deodex rom and tb fix, downloaded one app and now I have insufficient memory? Tried sd fix KitKat no go.???
PS
This problem is affecting a lot of phones that upgrade to KitKat so don't blame anyone person. Google who owns android design KitKat and probably all new versions after to not be able to write to SD. So let's hack away until someone comes up with a solution.
PS
Won't SuperR's flashables for permission changes do the trick?
No... flash before and after installing tb...no go...my Google apps can not even update themselves before I get insufficient memory? I have read that it is a permission issue with platform XML file. Tried xposed module
for kk SD...no go. I can't even download the tapatalk app, have to go thru web browser just to post this message.
@SuperR that's what I needed. TY.. There are some decent ROMs built already and I like to switch between them all. I'm sure with new source code on 4.4.2 the new ROMs will surface soon.
@bc I would like to download that themed ROM when you work out the bugs.
Just putting this out there, not a subject change Boost has 35 45 55 plans with extra data now
OK. I'm running into a permissions type issue where I'm not being allowed to move files/folders around (keeps telling me to enable root permissions?!) When I use any file manager (RootBrowser, CM file manager..) And Titanium Backup isn't able to change/modify/erase data/apks & backups. It THINKS it's doing its job but when u exit then return, no changes are made.
I'm running B12 Deodexed w/ partitions..
I had similar file management issues using ROM Toolbox Pro in SuperROM and initially with B12kitkat so I 'only' use it as an app mananger now. I ran 'fix permissions' using Nandroid Manager, cleared dalvick and now that I'm finally comfortable with ES File Manager, won't use anything but ES to modify files. No problems at all now. There was a good reason Super included Nandroid and ES in SuperROM in the first place. Their not fancy apps but do the job perfectly.
And thank you Super, you truly are the man. Everything is running perfectly with this updated version. Had some slight file management issues early on, but fine now. Read in previous post about Google Play issues so before I updated my apps, I tweaked my Google Settings first (which logged me in) and didn't experience any problems whatsoever when I updated apps through Google Play (not sure if that had anything to do with it) but all is great now. Anyway, thanks for the early Christmas present Super and Happy Holidays to you all devs and forum folks.
what do i need to root i downloaded the OTA 4.4.2 and i am not sure by reading what exactly i need to do just to root my phone. is there a step by step guide that could me made to help me?
