thowersome
Gone for a while, just wondering if the fc problem with the keyboard got solved
No. Turns out it is an Android bug present on many other devices as well. There was a fix released for it but it can't be implemented without building android from source. We do not have the stock source available so we are out of luck.
That's fine, I don't mind it just wondering if it got solved, appreciate the build though.
In your honest opinion, do you believe this ROM will open doors to more ROMs?
1) go to settings > about phone. Tap on SW version several times until it says you are a developer. Now you will have the option in the main settings menu
2) I also installed xposed with gravitybox and my launcher also force closed... Once lol. Never again after that.
3) You only need to flash the partitions once
Yes, but you need a computer. Use fastboot to boot PhilZ recovery and flash SuperSU. This method will root your device without flashing a rom or installing a custom recovery.This seems like a great rom. But has anyone figured out a way to actually root the ZTE 4g n9510 Kitkat 4.4.2?
Which PhilZ rom do I use and where can I get the flashable SuperSu?
What version of xposed installer are you using? Do you have a link for the download? I figure if it's working OK for you, I'll try that version.
Thanks!
Thanks!
Im currently using latest experimental xposed, gravity box, and tinted status bar all working wellI use the stable Xposed Installer, version 2.6.1. The link bcrichster posted has the stable one also, you just need to click "Show older versions" toward the bottom. I have not tried the experimental so I can't comment on it.
Ok so I've done some testing and have found that my 3g data speeds are double when only on CDMA mode... When on LTE/CDMA my 3g is like 1x speed... Anyone else experience this???
Hey I am representing the boost max forum and have a question... Did anyone complain to get the pushed update or is it something that they are rolling out
Is it possible for me to port over this ROM. I am a new developer and still learning. But I am taking the step since we have no development. I tried to port but during install, I had permission issues which kept ROM from booting
Going to give it a shot... Should I remove updater script for the specific device meaning so the device flash won't matter
Is that the base how you gave us super rom
