Deej029
ok cool.yea skeery huh lol
Yea the cricket fix aint so fixed lol, pip is looking into it tho.
What about CM7? Didn't someone say something about it working too? Or was that for Metro
works for Metro not heard from anyone on cricket.ok cool.
cool. I flashed back to Icarus for now. I like CM6 but my sis has been sending all sorts of things to me and I was like WAAAIITT...lol. When I got Icarus back on here I was getting like 2 a minute.works for Metro not heard from anyone on cricket.
I second that. The cookies offer still stands gentlemen....BTW!
Pip. I wanna say a HUGE thank you for everything you are doing. I looked in at some of the other posts and am just astonished at how some ppl can be. So "I" say thank you on behalf of everyone else.
To all the others that are wanting (demanding) this...PISS OFF!! You're about to screw it all up for the ones who really do appreciate the work.
ok...off my soapbox.
on the Metro settings, b4 the fix flash its 016 too but after its 027 n works.I've been reading a few diff forums and pretty much all of em are saying thatMCN has to be 016. when we change that (originally it is 16) it saves then dissappears. I have even edited the xml file to 016. open apn via voice dialer, and put in phone number and it again dissappears. hmmm...oh well...just ramblin.
Have you tired to change the settings b4 flashing the fix?
Thats the word lolI thought the fix wouldn't work for cricket?
Yeah I flashed CM7, edited the apn, flashed CWM (green) and flashed the mms zip for CM7, but it went straight back to the main CWM screen...didn't even say anything about being installed or anything, all settings in apn are the same...but still no mms. just thought I would mess around a bit while waiting.Thats the word lol
did you make sure to have the carrier setting set? colored dot in the radila button?Yeah I flashed CM7, edited the apn, flashed CWM (green) and flashed the mms zip for CM7, but it went straight back to the main CWM screen...didn't even say anything about being installed or anything, all settings in apn are the same...but still no mms. just thought I would mess around a bit while waiting.![]()
Yes. I flashed CM7 and edited APN FIRST. THEN flashed old CWM and then mms fix for CM7. no go...all good though.did you make sure to have the carrier setting set? colored dot in the radila button?
Oh if you flash the fix b4 booting cm7 once there will be no settings at all lol
Patience is a virtue.just sumtin we have to live with. Rather have no mms or no roaming indicator?? lolI just did the MMS flash. After though my lock screen got the roam indicator off. Any suggestions?
Question about CM6, sometimes my phone is stuck in landscape and sometimes in portrait. How can I fix this?
Wow. I guess I could have shared last night when Isaac released the fix in CM7 for cricket users. I changed it for CM6 and it worked. Thanks to PIP and Isaac for these two DAMN GOOD roms!!!! You guys are both awesome!
...what needs to be done to apply your fix to my phone?
do i need to wipe or just flash a .zip file? (and where is the fix at?)
... thanks!
NO. I did not flash anything. what I did was steal the apn xml file from CM7 and replaced CM6 apn xml file with that one. was having comp problems with internet so I couldn't post it...but no I DID NOT flash anything but the rom...lolyall REALLY need to read. holy hell.
the mms fix that is flashable is ONLY FOR METROPCS USERS.
IF YOUR A CRICKET USER AND YOU FLASHED THAT YOUR..... fill in blank.
so i just have to dl cm7, unzip and find apn.xml file, unzip my cm6, swap cm7 apn.xml for cm6 apn.xml, re-zip cm6 w/ updated file, then flash THAT to my phone?NO. I did not flash anything. what I did was steal the apn xml file from CM7 and replaced CM6 apn xml file with that one. was having comp problems with internet so I couldn't post it...but no I DID NOT flash anything but the rom...lol
but now there is an update anyway... so its all good.![]()
ummm...wow...you trying to make it hard on yourself.so i just have to dl cm7, unzip and find apn.xml file, unzip my cm6, swap cm7 apn.xml for cm6 apn.xml, re-zip cm6 w/ updated file, then flash THAT to my phone?
could i just take my cwm recovery file and do the swap there so i don't have to go through all the other changes i've made so far?
thanks for the help again!
just go download the new CM6 or CM7
