BobZhome
Developer: Blarf
Builder: BobZhome
Current Version: CM7.2.0 RC1-MS690-BobZhome (3-24-2012)
People worked with/owe thanks to:
Alex Zepeda a.k.a Blarf - For his great skills on developing for the Android.
reppard & somedood81 - For help with getting need files
What Does Not work?
Probably MMS
Changelog
3-24-12:
2-2-12:
1-16-12:
1-5-12:
11-13-11:
10-16-11:
09-30-11:
09-16-2011:
09-11-2011:
09-08-2011:
09-05-2011:
09-03-11:
09-2(pm)-11:
09-2(am)-11:
08-26-2011:
Download Links
NOTE: If you end up having issues, always go back and try wiping. Start fresh and see if things don't improve.
NOTE 2: It'll take awhile for everything to settle down. Especially after installing gapps and syncing accounts. Give it a few minutes to settle and reboot a couple times. The system will speed up after that.
Build 3/24: CM7.2RC1-MS690-BobZhome-032412.zip MD5checksum= 824fca17bcb5eb8e7bc7eab4ef61718d
Custom Gapps(with old version of market): gapps-gb-20110613-BobZhome-v2.zip MD5checksum= 336211d87495e440e46e6d1f5b37d4d7
Latest Gapps: gapps-gb-20110828-signed.zip MD5checksum= 1647897d8ac3efb04723d2ad2c361a3f
Helpful Tips
Overclocking is available in Settings --> CyanogenMod settings --> Performance --> CPU settings. Tweak it as you like, but know this: not all OV's were created equally.
Builders Notes
All credit goes to Blarf(the Dev)...please donate to his beer fund!
How Can You Help?
Please don't thank me, instead donate to Blarf for all the great work he has done.
Enjoy!
Builder: BobZhome
What Does Not work?
Probably MMS
Changelog
3-24-12:
- sync'd up with CM: now at CM 7.2.0 RC1(was Release Candidate 0)
- sync'd up with CM: Add option to enable/disable the ICS rotation animation (Cyanogenmod Settings -> Display)
- Added: Roboto Clockopia.ttf(for the lockscreen clock) - Thanks to Whyzor
- Kernel: Reverted back(The 2.2.2 changes would not boot)
2-2-12:
- sync'd up with CM: new ICS transitions and Blade style lock rings
- Tweak: MMS(hopefully working without flashing fix)
- Kernel v10.6: Added changes from ROM kernel 2.2.2
1-16-12:
- sync'd up with CM: Now with Holo style lock rings(look great with ICS theme)
To enable: Settings > CyanogenMod settings > Lockscreen > Style options > Ring-Lock style > Holo style - Fixed: Charging while powered off
Note: To turn on phone while it is plugged in, just hold the power button until you see the first LG screen
1-5-12:
- sync'd up with CM: Now at 7.2.0 RC0
- Added: Center Clock tweaks by JerryScript
- Added: Ability to use adb over networks - TO USE: You have to go into wireless settings to get your ip address, then go into development and enable adb over networks, then connect from a command prompt with: adb connect IP_ADDRESS:5555
So for example: adb connect 192.168.1.2:5555
11-13-11:
- sync'd up with CM: To many changes to list
- Added: Custom carrier label *See Screenshots here
- Changed: System Font to Roboto
- Tweak: Permissions(Fixed: video recording with audio)
- Kernel v10: A bunch of optimizing
10-16-11:
- sync'd up with CM: CM 7.1.0.1
- sync'd up with CM: SemcRIL: Improve AID selection
- sync'd up with CM: Camera Scene Mode NPE Fix
- sync'd up with CM: RingLock - Fix animation & added arrows to pressed ring bubbles to indicate selection
- sync'd up with CM: audioflinger - Allow bundling the A2DP interface
- sync'd up with CM: Fix setting connection status when switching profiles via 3rd party apps
- sync'd up with CM: libcameraservice - Workaround for nvidia TTF bug
- sync'd up with CM: Updated versions of Superuser & su
- Tweak: GPS - more detailed conf file
- Tweak: Wired Headset - working controls
- Tweak: Camera - Fixed: Touch to focus
- Tweak: Camera - support image/video stabilization
- Removed: Darktremor Apps2SD
09-30-11:
- sync'd up with CM: CM 7.1.0 FINAL(no longer Release Candidate)
- sync'd up with CM: Android version - Updated to 2.3.7
- sync'd up with CM: SuperUser - Updated to version 3
- sync'd up with CM: New Ring Lockscreen style
- Tweak: Accelerometer - reverting SensorDevice class to 2.3.2 state(by mik9)
- Tweak: Camera - Increased picture output size
- Kernel v9: Replaced Smartass and Interactive governors with Smartass2 and InteractiveX governors
- Kernel v9: Added: CIFS(Common Internet File System) module
- Removed: Adobe Flash Player for ARM6 hack
- Removed: MMS hack - Going to work on getting it to work correctly
09-16-2011:
- Sync'd up with CM
- Changed: eri file - Hopefully Playfulgod's works
- kernel v8: a)OverClocking: Removed top scale b)Update: futex compound knowledge c)Added: futex_q static initializer
09-11-2011:
- Fixed: Camera - No longer inverted <--a big Thanks to Playfulgod for figuring it out!
- Added: Adobe Flash Player for ARM6 hack
- kernel v7: a)Video Drivers: reverted b) Over Clocking: Added two more c)Battery: Enabled charging on wall chargers that ID as "USB" devises d)WiFi: 1)Force Powersave Mode 2)Disable wakeup IRQ when devise sleeps
09-08-2011:
- Kernel v6: a)Optimized b)Video Drivers: changed
09-05-2011:
- Fixed: WiFi
- Kernel v5: a)Fixed: Overclocking scaling b)Added: Interactive and Smartass governors c)Changed: video drivers
09-03-11:
- Kernel v4: Make Over Clocking show up in CM settings
09-2(pm)-11:
- Fixed: Notifications Carrier info banner
- Fixed: MMS
- Kernel v3: a)Fixed: Over Clocking b)Switch: to TCP-Westwood
09-2(am)-11:
- Sync'd up with CM
- Updated to Blarf's repo: Camera geo tagging fixed
- Removed Market from build(grab custom Gapps from download area(below), if you want the old market)
- Kernel v2: a)Added: Over Clocking b)Removed: No physical keyboard
08-26-2011:
- Sync'd up with CM
- Initial setup of the MS690
- Removed all languages except English
- Removed FM Radio - OM has no radio
- Removed 2 extra themes - theme chooser/manager is still included
- Removed all live wallpaper, but kept live wallpaper chooser
- Removed ADWLauncher
- Added LauncherPro
- Added old Market(I hate the new Windows 7 looking Market) - If you flash Gapps, it will update you to new market
- Added Darktremor Apps2SD version 2.7.5.2
- Added ringtone added: "Somebody's Out There" by one of my favorite bands: "Triumph"
- Changed bootanimation
Download Links
Here is a QR code for a direct download to your phone:
Helpful Tips
Builders Notes
How Can You Help?
Enjoy!
