idk if it was just me but, the old cm7 hardware acceleration didnt work, wondering if anyone can confirm it working on this.
(You can check by playing a movie or video in Hardware decode mode)
Also my spare parts tip I posted a few posts back helps. If all else fails just swipe across the screen with your finger and the lock screen will appear
I enabled stagefright using Blade Buddy from the android market...and it did give me some hardware acceleration but did nothing for the screen lag.
yeah I was referring to the hardware accelerationI enabled stagefright using Blade Buddy from the android market...and it did give me some hardware acceleration but did nothing for the screen lag.
For your screen lag on The lockscreen try using a live wallpaper it will make it appear alot faster.
My Market isnt working and there are no live wallpapers..
This ROM has been terribly glitchy for me. Its has been causing apps to freeze constantly, and apps left and right will force close. I knew I should have done a NAND backup of the Beta Rom. Oh well,
Can anyone upload this to google docs the mediafire is not working for me
im doing it right now but I have slow upload speeds so give me a bit.
/e
Google Docs Link
https://docs.google.com/leaf?id=0B9y4Oq0y19LxM2Q1NWJlYWEtZTA1YS00MWQ1LTkwMmItZmYxYTU1YWU1NjM5&hl=en_US
Hmm, I couldn't even get antutu to run, maybe it doesn't like my backup...
How about quadrant?
Yup.
