Root [ROM][WIP]CM7.2.0 RC1-BobZ
Yeah I use SD Booster...I'm gonna flash an updated a2sd script and see if that helps. Hopefully it works with this rom. I used it on the old cm7 but results always vary :)
First off, thanks for the wonderful rom and all your hard work, Reppard.
Inspired by this rom to join the world of development I have created a simple fix for that annoying "Metro PCS" that haunts the status bar and lockscreen.
To install do the following:
1:Place file in a folder that's easy to spot in custom recovery
2:Wipe the dalvik-cache to be safe
3Disable signature verification, flash, and say goodbye to the last piece of metro likeness.
This update does not change anything except the Metro PCS in status bar and lockscreen. It does not alter any images and shouldn't damage your device at all.
PM works wonders for contacting me as I use the Phandroid app more than I use my PC
:D
Download Here: http://db.tt/dAVkU4I
I'll be updating this in the near future...I'll also post the UnDo if anyone wants it
(I'll be starting a new thread for updates and possibly add-ons)
Someone Try this I havent yet but it might just work.
UaeKzSL
Dark tremor beta 4 does work...DO NOT WIPE ANYTHING BEFORE FLASHING!
After flashing, from terminal emulator type
#su
#a2sd datasd
(# is not to be typed...its a just reference)
Hit enter, wait, when its done it will reboot and you're good to go. The latest script is over @ XDA forums
After flash from terminal emulator type
#su
#a2sd datasd
I'm not to familiar with xda forums.
As far as I know it works for the old cm7 beta and this one as well. I haven't used any other roms since the old cm7 came out.
When I tried to use the terminal emulator for that a2sd it said at the end no partition Available -_- but I know I had it partitioned
