ARGH im very excited that the camera is working but YOUR LINK IS DEAD geofferey....
So geofferey, flashing your backup shouldn't cause the boot failure now right? And does build.prop still need to be replaced for verizon phones?
alrighty, I know a little late but, here. A zip of the camera you can flash. signed and good to go.
. Thanks for the patch, it's still of use which means your not late. Some people would probably prefer flashing a fix instead of a nandroid backup from somebody else. I have found that you gotta be careful not to make changes to the system (such as font's lol) when making the backups for other people to use.how usable is this build right now?
I'm using this ROM on my daily phone. It's pretty much completely usable after the fixes that kappacat mentioned:how usable is this build right now?
Updated OP(first post) to new build
Feed back welcomed/needed
Thanks!
Thanks!
Thanks!
I was read back and found this interesting...can you try changing the permissions of the files I have in the current rom to see if it works?got my camera working.I copied all the files in the system/lib/ that had the word camera in them of the rom I mentioned earlier and changed the permissions of the files i copied over to rw-r-r--
Thanks
It didn't fix the rotation issue, and I'm also having an issue with callers not being able to hear me now.
