If a ROM has built in CPU management where can I find its setting vs. installing setcpu and possibly making ROM unstable?
what rom are you on? if it is cm7 then go to settinings/cm settings/performance/ cpu settings.
For what it's worth I often use set cpu with these roms and don't have any issues
No, you really don't need to use it. I use it on the off chance that I want to use a screen off profile (which is basically never, since Smartass and InteractiveX governors both include a screen off profile by default) and I like some of the info that is available in SetCPU that isn't with the CM7 Settings menu. Like I can tell if anything is pegging my cpu at 100% usage or see what amount of time my CPU as spending at a given speed.Is CM7 one of the few ROMS that you really need to now use setcpu with? I've never had much luck with CM7 anyway, always seems to be glitchy and laggy for me, not sure why, could just be me.
