I'm currently running Apex on my X, but have the issue where, after using the Blur Dialer the first time, it shows up in sensor usage 100%, and drains the battery.
I would like to try a ROM that doesn't use the Blur Dialer. Are there any?
Thanks!
are you sure its actually killing the battery?...because i have had the same problem with the dialer using 100% sensor, and even so ApeX kills Liberty on battery life...
