This is an apk for rooting the L38C, which I'm told is basically the same thing as the L3 E400 and L35C. I didn't see a specific section for the L38C, so I'm putting this here. It uses a bug in the backlight driver to gain root, which affect several models from LG. This apk specifically checks for the buildprop for "LG-L38C" and "LGL35G", but if an owner of a L3 E400 want to try it out, I dont mind adding that property to my whitelist.
How to use it? Install the apk from the bottom of this post. It should show up as "L38C_NoobTool" in the apps. Install ministro 2 from the play store. Start the "L38C_NoobTool" app, it will start ministro which will download a few mb of c++ libraries, and hopefully show you a button that says "Root Me". Click that button, and if everything works, it will write the su binary to /system/xbin/su. Then install the superuser app (supersu won't work with this su binary).
After its done, neither my app or ministro are needed for root to keep working.
If you want to use superSU instead of superuser, follow the directions as above, and then install the superSU app. Then open that app, and tell it to update the su binary. After that, superSU will work, and superuser will not.
L38C/L35G root app - http://www.sendspace.com/file/6dljxo
Ministro 2 app - https://play.google.com/store/apps/...xLDEsIm9yZy5rZGUubmVjZXNzaXRhcy5taW5pc3RybyJd
