Root root cricket zte grand x max
Take a screenshot of it. Twrp let's you take screenshots the same way you normally would.
After that everything install fine there's was no problem with the installation and I read the message when the phone booted up so I was un able to take the screen shot
That's what I was thinking its just something it says because of the way I wrote the script. It doesn't affect anything the ROM still installs properly
Is there any chance you could make a Rom with Xposed pre-installed? I have been banging my head against the wall for about a full day now and it hurts!!
Here is what the Xposed installer is giving me.
Best as I can tell it's occurring when the following part of the script is being executed:
install_nobackup /system/framework/XposedBridge.jar 0 0 0644
I think I figured it out!!!
I deleted the files in /system/media for startup animation, startup sound and shutdown animation. This gave me enough space to be able to run the Xposed Installer. I'll report back later whether that fully resolves the problem or not.
OK I'm about to try and install those zips to check if I can install xposed with that because I had it install then I run the new zip with the splash screen and that's there I had trouble
When I installed the Xposed apk I got that error message I posted above
