Ok guyphs i understand thats its supposed to be on the sd card BUTT it not. having said that i have done a couple of less involved phone systems (tracfones). In your post you said their was 4 things you would need , one of them was ,download the superuser flashable zip file . OK i did that and the rest of the steps (downloads) in this section of your post. Now as i said before kies did not work, tried several times, did not work. So i downloaded a driver from samsung, another person said it worked for them. guyphs that was a mouth full 1st question will the samsung driver be ok ,or do i need the kies version. 2nd question, In your post ( the four things you needed) that was the first time you talked about SU the next time you talked adout it it was supposed to be on my sd card already, So how does it get their, is it supposed to upload on my phone . do you have to unzip the file on the pc or what exactly. Prob. just me as I am fairly new to this ,but after doing the other phones I was feeling lucky about this phone, Please try to make something out of this for me . Now i have tried to get root twice and have downloaded the custom recovery and AGAT kernal twice ,and have went back to stock boost twice .but no superuser. STUCK with stock bummer
Is there a way to get Superuser without an SD card?
The system update FI22 is out... (Boost Mobile GS2)
Problems if you have FH29 rooted and want to update to FI22:
I'm running now the FH29 and tried to update it to the newest version (FI22) but that gave me an error that didn't surprise me because I'm rooted.
I did a Nandroid backup before anything....
I went back to stock and did both updates FH29 and FI22, then I rooted the phone (flashed Agat and then Superuser-3.1.3-arm-signed.zip), everything seemed ok until I realized the 3G wasn't working no matter what I tried. I flashed my Nandroid backup on top of this without results. Finally, I went back to stock again, updated to FH29, and flashed my Nandroid backup and everything is working now... (without FI22)
If anyone has a solution for this let me know, it looks like this rooting metod doesn't work for FI22, for some reason blocks the 3G and I don't know what else....
Thanks
Sent from my GT-P6810 using xda premium
i took the battery out multiple time .. did power and volume up keys nothing worked... dnt know what else to try
Ok im starting to worry a bit, PLEASE HELP Thanks in advance.
yes I have come to that conclusion about both titanium installs. I have just reinstalled guyphs guide still the same but i do have a yellow triangle on boot screen. what now . i dont think my phone is bricked. I understand that titanium is pretty much running my phone so when i uninstalled it thats what went wrong, I even went online on my pc and installed titanium with no luck. should i run the guide again(guyphs guide) Thanks in advance
I went to my pc to titanium and to see if could reinstall it from their, dint think it would work though. yep i reinstalled the guide again does not work. like i said before when i uninstalled titanium one and reboot then it was stuck in boot screen. Sooooo what now?
