root newbee question
johnny124
So I did the one click root, worked great. I then did the titanium backup, wiped clean to factory settings to install new Zen Rom. after the wipe i cant find titanium backupk? So now i am back at stock without any of my backed up info. Any suggestionsk?
Have to redownload from the android market first after you flash a new rom and TB will do the rest
Once downloaded just hit menu then batch, from there you can scroll down and select to restore all apps or missing apps. I recommend only restoring the apps themselves though and not thier data.
