[ROOT] One-click root for LG Lucid :: 4/18/12
k0nane
Android Expert
k0nane, Shabbypenguin, and bliss present...
One Click Root for LG Lucid
About
Hi folks. Your phone's basically a rebadged Connect. It can be rooted the same way. So we didn't actually have to do anything! This would have been out sooner if you folks had responded to our "come test with us" almost a month ago... ;) The talented Dan Rosenberg already rooted the LG Spectrum (see here) and was kind enough to post a one-click for Windows and OS X/Linux. Myself and Shabbypenguin don't have much to add - it works, Mr. Rosenberg (bliss/@djrbliss) did all the work, you all have him to thank.
But, without further ado...
How to Install
Your device must be in USB Debugging mode. To turn it on, go to Settings > Applications > Development and check the box.
Linux/Mac: Connect your device to your PC, unpack the archive, and run run.sh. You may need to chmod 755 run.sh.
Windows: Install the LG Spectrum USB drivers (download), unpack the archive, and open run.bat.
Downloads
We do not use file hosts with waiting times or CAPTCHAs!
Windows Download (Direct) | Mirrors :: Direct #2
Linux/Mac Download (Direct) | Mirrors :: Direct #2
Credits
  • Dan Rosenberg: security researcher, rooter, friend of the Hit Squad, did all the work
  • markolo25: locating working drivers
  • Shabbypenguin: Shabbypenguin
Don't forget to join us in the IRC channel! If you want to donate, donate to the EFF, Red Cross, or Mr. Rosenberg.
P-O-S-T :: R-E-S-E-R-V-E-D
Original artwork by Pendulum via Gasolin3.
...for future use.
Follow me on Twitter @k0nane and @publik0!
Follow Dan Rosenberg on Twitter @djrbliss!
I got past 'waiting for device' initially, but it stopped a few steps later. Ended up trying to run it a couple times again, but got stuck at 'waiting for device' each time. Ended up leaving the 'waiting for device' message up while leaving the phone connected and restarting the phone. Did a couple reboots and then progressed to the root.
Just installed ROM Manager, so it looks like superuser is working. (Although there doesn't appear to be a Clockwork recovery for our phone model?)
Aw crap. Was screwing around trying to install a version of clockwork mod recovery and now the phone's loopin' :p
Just got this phone today. Glad to see an easy method for root is out.
Had to troubleshoot a little; tried rooting before the system update to no avail. (I did end up updating....probably didn't matter though).
To get it to work, I followed the above instructions and when the command prompt said "waiting for device" I rebooted the phone. It then went through all the steps including several reboots and now I have root :)
A lesson to all you youngsters out there: DON'T INSTALL ROM MANAGER AND CLOCKWORK MOD! ;)
Had to order a replacement and go back to my old phone for a while (phone is backordered again. must be popular). Ah well, live and learn. :cool:
I cannot click USB debugging unless the USB is unplugged, after its plugged in it greys out, either way I ran the run.bat and its staying at "waiting for device"
any thoughts?
**EDIT** I rebooted while it was "waiting for device" and now I have root, thanks again.
sorry :/
we need to get virgin dumps of this device, so if someone isnt rooted could get em that would be awesome
My LG Lucid was delivered today is currently at home still in the UPS box. I should be home in about an hour, but not sure when I'll get time away from the wife to use the new phone.
If there is a somewhat easy process to get a virgin dump from the device that works in Linux (my preferred OS and the only one on my preferred home PC), I would be happy to provide a virgin dump. I'd also like to know the preferred file host to upload it to.
sure in fact ill edit the one click root to get it, that way at the end of it youll have a nice newly rooted device and the image file :)
www.shabbypenguin.com/OUDstuff/cayman/lucid-one-click-dump.zip windows
www.shabbypenguin.com/OUDstuff/cayman/lucid-one-click-dumper-nix.zip linux
i recommend dropbox for uploading :)
The dump didn't work, although I think root did. Here is the output: [root@twin-rockets spectrum_root_linux_osx]# ./run.sh ./run.sh: line 22: [: too - Pastebin.com
This was done on Arch Linux 64-bit using the adb binary from the android-sdk-platform-tools r11-1 AUR package.
I've used up my allotted time away from the wife tonight, plus I'd like to use my new phone, so another dump attempt will have to wait.
bah im an idiot, forgot shell in front of the command, anyways wont much matter, your system is now tainted with root :P
need someone else now that i fixed teh scripts :/
For the newly posted root/dump scripts, will the linux version work with OSX? I don't have a windows pc at the moment. Thanks
Has anyone gotten tethering to work on the lg lucid? Using a rooted lucid, I have barnacle installed, and can get clients to connect, but can't download any actual data. Is vzw blocking this somehow?
Is there any way to confirm being rooted beyond the CLI saying it's complete?
So far I haven't found any benefit to being rooted and I can't uninstall any bloatware without paying for an app to uninstall apps from the system folder.
edit: I realized that superuser gets installed and after installing titanium backup I was able to uninstall bloatware.
Since this is a rebaged Connect 4G, will mods from the connect (ie Kernels, CWM, Roms) if and when available work, if not what will need to be done to make them work.
I assume roms from the connect may need something to make them work on verizon's network.
roms wont work, kernels if any changes need to be made will be minimal, expect more stuff from the lg viper tho it is sprints first lte phone so i imagine it will get more attention then the lucid or connect
