Hi,
This is my first post although since before I got my Desire I've been using these forums and finding them a great source of help for all things Android.
I'm sure my problem/query has been covered before but I'm at work so can't spend hours searching through the forum so if somebody could point me in the right direction it'd be much appreciated!
Last night I finally got the courage up to root my unbranded Desire in order to create a Nandroid backup and intended to flash a new Rom, but after successfully rooting using unrevoked but when I came to do a Nandroid backup it failed with the following errors when entering CWM Recovery:
E:Can't find MISC:
E:Can't mount CACHE:recovery/command
E:Can't find MISC:
E:Can't mount CACHE:recovery/log
E:Can't fint MISC:
I found this when looking for an answer
[CAUTION] New HTC Desire model spotted. PVT4 - S-OFF: works (AlphaRev 1.8) - xda-developers
And using the test suggested with terminal emulator it looks like I've got the new PVT4.
All this talk of AlphaRev and AmonRa is really confusing me and I'm not sure how to proceed...I downloaded the AmonRa .img file and tried rerooting using that in unrevoked but got a "Is your firmware too new?" error.
Can anybody give me a simple step by step guide to get around this problem please?
I installed the free version of Titanium Backup and did a full backup, then copied my whole SD card contents to my computer, so I do have a clean copy of everything.
Then I tried flashing with Miui anyway, but got the "Error: Can't mount CACHE" message again when trying to erase all data etc from Recovery. Ran Miui from the SD in Recovery and seemed to get a completed/success message, but when I rebooted it just went back to my stock Sense UI....if nothing else, if I were to reflash the stock RUU, would I have this same problem too of the flashing not working?
It's really frustrating me as I'm not particularly liking Android OS that much in it's stock/Sense configuration but really like the sound and format of Miui and was hoping it would salvage Android as an OS for me, but after the frustrations last night I'm really starting to hate it
Cheers!
Andy
E:Can't find MISC:
E:Can't find MISC:
E:Can't fint MISC:
Cheers!
Andy
