Welcome to the foums! Hope you enjoy your stay
Well, if you'd like to delete some of those pre-loaded bloatware from Sprint and HTC, you have two options:
1. Download a new ROM. (Check the
Rooting for Dummies sticky on this forum to learn about ROMs, rooting, kernels, etc.)
2. Download one of the apps from the Market such as "Root Uninstaller" or "Titanium Backup". I highly recommend Titanium because it has more uses than just deleting stock apps. Once you've downloaded it, allow it SuperUser properties, etc. then go into Backup/Restore at the top of the page. Then click "Menu" and go to "Batch". You have two options, either go to "Freeze/Defrost" and select which app(s) you'd like to "delete". This is the preferred way to uninstall these apps. What it does is freeze the apps from being used and being accessed. You can also use the "Un-Install" function to delete these unwanted apps, but I wouldn't recommend it because you are a beginner and sometimes you may uninstall a much needed app and not be able to get it back if you need it. I only use this to delete apps like ones from Sprint such as their navigation app.
If you want to delete through a new ROM, most ROMs come without the bloatware once they are flashed (installed). Read up on the ROMs before flashing them because some ROMs rarely do not have features like HDMI, front camera, or 4G. But most ROMs now have those unless they are old and outdated. I would highly recommend checking the bottom of my signature (or
here) for a list of ROMs and kernels available for the Evo phone.
There is so much more to do once rooted. You've made the right choice because you've unlocked your phone to its full potential. I would suggest browsing the internet and our "
Evo 4G All Things Root" section and just see what threads there are about the cool new ROMs and kernels available. You can do so much now like wifi tethering for free (without paying Sprint $30 a month extra for the feature), 100% customization through ROMs, apps like CacheMate that allow you to delete all your app's cache with one click of a button, and much much more! To search for some of the cool, new, and unlocked root apps from the Market, I search using these key words "root access", "root", "super user", and "superuser". Searching the Market with these words usually will yield you some apps and give you some ideas as to what root can do for you as a user. Also search the internet through searches and search for lists like ones about "top 10 root apps for android" or something and they'll list some cool apps for root users and explain what they do in detail.
Are you using Amon-Ra recovery or ClockWorkMod? I use Amon-Ra because I find it easier and better but if you prefer CWM, I would recommend downloading their app from the Market too called something like "ROM Manager". Even if you have another recovery like Amon-Ra, it's okay because you can still do some things but most is limited. Once you've downloaded this app, you will be able to flash ROMs and kernels through the app and it can take you directly to your recovery with the click of a button instead of you manually turning it off, rebooting, etc. You can also download ROMs through it and some versions of the app allow you to see user reviews of the ROMs as well as a complete list of their versions for each ROM.
My personal top rooting apps that I use include:
-ClockWorkMod ROM Manager (explained above)
-CacheMate (deletes all app cache with the click of a button)
-AdBlock (blocks ads from apps on your phone)
-Root Uninstaller (freezes/removes stock apps as well as restoring them)
-Root Explorer (allows you to search more areas of your phone instead of just the SD card's contents)
-HDMwIn (allows full, 100% mirror of the HDMI to any HDMI device such as instead of just streaming media like from YouTube or your personal media library, you can now see EVERYTHING from your phone on your HDMI tv if connected)
-Titanium (explained above)
-ShootMe (not available on Market last I check a week ago but can be found online on other places; takes a screenshot (picture) or video of whatever you are doing on your phone)
-wifi tethering/Sprint Hotspot hacked/etc. (allows wifi tethering to other devices; basically allows other devices that have wifi to pick up your phone's wifi signal and use it to gain internet access...basically makes your phone a wifi hotspot. Some apps are Barnacle, Wifi Tether, and more.)
-Superuser (comes pre-installed on most rooted phones; allows security for root access apps so your phone will be protected yet still be controlled 100% by your)
-WiMAX Notifier (allows a secondary LED on your Evo phone to be used for notifications; it is a bit tricky to get started but is nice once used)
Some apps like Handcent do not require root access to be used for most of its features. But then they have some "advanced" features that can be used such as it being able to use the secondary LED on your phone. Some apps also work like this and are not generally advertised as having root access.
If you have any questions, feel free to private message me or ask here or anywhere on our forums. This is one of the friendliest places to be
Have fun.
