Root Rooting disabled usb pc connection and charging
it starts up correctly, im using it i build a dock charger out of legos to charge it, i instaled the Sony PC Companion software noting it says device not recognised i used divrent Pc's, USB cables and a even a Sony Xperia Z3 (my Pc reads the Z3)
Upvote 0
Hmm, that's not a good sign.
All I can suggest is to download and install FlashTool on your PC. This can then be used to download and flash a stock firmware to the device which will (hopefully) solve the problem.
  • Like
Reactions: funkylogik
Upvote 0
How can i root my phone without using a computer?
There are a few standalone rooting apps available, but tbh I always advise using a computer if available as it gives you a "get out of jail card" if things go wrong. The aforementioned FlashTool can root all but the latest 5.0.2 firmware, for example.
In any case, I don't advise proceeding further until the device is working correctly.
Upvote 0
Flashtool doesn't require root, it is what you will use to flash new firmware and possibly to root, depending what method you use.
I had a problem with my Z1 ages ago with the computer not recognising it. I think I just downloaded the drivers from Sony and that fixed it. Worth a try. Believe yours are here...
http://developer.sonymobile.com/downloads/drivers/xperia-z-driver/
Upvote 0
Upvote 0
BEST TECH IN 2023
Smartphones
