11.using a file manager of some sort or even through your computer via usb, you should rename or delete the PC36IMG file on your card...
Only if you're using the Stock rom the SU file is baked into all custom ones.How about the SU file? Do we need to leave it in the SD card?
BTW, TYVM for the walk through!!! Had couple of glitches on the way (incl. crashing the PC several times), but the forum was helpful enough to pull it through. :beer:
You can leave in on there...it wont hurt anything
Edit: Where are my manners? Welcome to the forums![]()
Thank you Sire! Pleasure to be here![]()
Mike you're always to quick for me.![]()
NICE!!!!!!!!!!!!!! glad it worked for you.....now go and get your flash onHow about the SU file? Do we need to leave it in the SD card?
but is he faster then a robot?Mike you're always to quick for me.![]()
Frankly idk what "the Stock" isI just followed the instructions on this forum to root my phone. And, in addition, tried to replace the rom to Amon Ra 2.3 (because OCN was saying it's a better one). So after doing it, I noticed there a 2 zip files in the Root. So just was wandering if I can delete both, so they don't confuse me
lol
Hello I did this a while ago and everything worked fine, i used revolutionary once i downgraded and i used the revolutionary unroot method that you had a link to and it worked fine s-on and no watermark. Then I did an ota update and the locked(oow) popped back up in the bootloader, is there a way to get rid of this or can i just not do an ota upgrade if I dont want the locked(oow) in the bootloader?
Im trading in my phone into sprint on the 19th to get money off the htc one![]()
Im worried that if it says oow they wont take it.
tahmeee said:Im trading in my phone into sprint on the 19th to get money off the htc one![]()
Hi im new to the Evo and when i was trying to root my HBOOT was 2.18.0001. I was wondering how i could fix this to 2.15 or .16... pls help![]()
If there's one person I can vouch for on the HTC platform, it's ocnbrze; two years ago, he helped me learn, install from the REVOlution site, and even showed me how to fool a bootlloader into accepting a stock ROM with the addition of .zip on the file. He's patient and possesses an even temperament, which most people of higher intellect cannot claim. I give you the one, the only - ocnbrze (insert applause here). You're all in good hands.View attachment 64910
